washers
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Topic: washers
    Posted: 11 Apr 2021 at 12:48pm
What are your opinions on using washers under head bolts if there were no washers from the factory?  How about thread sealant on the bolt heads?  I used never seize under the head and on the threads, but haven't torqued anything down yet, just finger tight.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2021 at 1:03pm
If it didn't have washers and there is not a service bulletin, or other qualified instruction, saying to add them, I would not add them.  Sealant and lubrication should be spelled out in the service manual if needed.  I follow the manual instructions. Run a tap in the holes and blow them out to clean them.  Wire brush the head bolt threads if they are being reused.  Light wipe with oil at the most, if nothing is specified.  Cast by it's makeup provides its own lubrication.  JMHO
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2021 at 1:39pm
For general fastening, if machinery came with lock washers, Dad would always re-assemble with added FLAT washer first, then the lock washer then the nut.  When nylon infused nuts came out, I would see him throw them away and go to the flat washer, lock washer and standard hex nut routine. He would "coast" nuts on by hand then give them a torque with the wrench.  He passed on last year at 97 years old.  R. Musgrave
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2021 at 4:06pm
head bolts get a couple drops of oil and assemble.. thats it.... you only use sealer on things like manifold bolts or water pump bolts that go into the water jacket.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2021 at 7:57pm
Thanks guys, I certainly appreciate your input!   Maybe was a dumb question, but it can't hurt to ask
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2021 at 8:44pm
Only use harden washers under any thing that gets torqued. No hardware washers.       MACK
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 6:40am
Thanks Mack!
