Was this made in 1986. ?
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Topic: Was this made in 1986. ?
    Posted: 29 Dec 2014 at 11:56pm
8070F3319 86
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 6:16am
Doubtful??? I've never seen a year designation stamped on a tractor like that before, but it certainly does look factory.
Edited by Lynn Marshall - 30 Dec 2014 at 6:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 9:27am
the bible says 3354 was last # built-dated 1985
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 10:00am
That is strange, mine is 8070FS 3326 85
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 10:03am
That sure is different. I was told of a 6070 that went through a dealers shop. When they pulled the valve cover off, some one welded the words "last one" in the under side of it. If it isn't yours you might want to make it yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 12:14pm
Its mine but it can be yours its in the classifieds
                   IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 12:15pm
I have seen it on several of the 8000 series. Saw it on a 4w220 and 4w305. And the year stamped, matches the year of the serial number.
                             IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 1:17pm
I will have to watch for that data on the next 8000's that I come across. See John, you're never to ''smart'' that you can't learn something. Also, that is a sharp 8070 that you have for sale there.
