was a deere guy but starting to fall for allis
stolfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stolfarms Quote  Post ReplyReply Direct Link To This Post Topic: was a deere guy but starting to fall for allis
    Posted: 05 Jul 2012 at 11:31pm
wanting to know more about the 8550 series an the 4w305
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 7:24am
I am supprized someone has not jumped in here to 'say' something... i do not know about that series so willl bump you back to the top. if you read much on here you know Orange can be addictive................as much as the green
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 11:51am
305 pto     252 drawbar hp
4w-305 is basically the same with some improvents, different cab and sheetmetal, different drivelines to rear.
both use 731 CU 6cyl motor.  basically a destroked 844 from the construction/crawler line.
very heavy loads and abuse can hurt drop boxes causing expensive repairs or worse...  junk.
i have worked on drop boxes for minor issues like cracked tooth on a gear and a gear siezed to output shaft just after dad purchased.  otherwise we have used 2 for 12+ years without major incident.  overhauled one when we bought it, still going strong.  unless damage is on input shaft or counter shaft, drop box work can be performed in tractor.  parts are getting harder to find though.
what else do you want to know?
Edited by CAL(KS) - 06 Jul 2012 at 11:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote stolfarms Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 2:12pm
can you just not get the input or counter shafts anymore? how much are engine kits for one? and an older gentlemen  from this area had told me that the allis trans that are in the 8550 and 4w305 are the same as the versatile of those years is that true?
Post Options Post Options   Thanks (0) Thanks(0)   Quote stolfarms Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 2:53pm
oh and what rear end and front ends did they an are they pretty good?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 3:13pm
I know Steiger used some Allis-Chalmers transmissions. I think it was the transmissions Allis built for the 8550 and 305.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 4:04pm
yes i think some steiger applications used the allis transmissions, which ones i dont know, however the gears are different (# of teeth) and cannot be used in 8550, and i suppose 305 applications.  found this out searching for parts
well some parts are available but most are salvage.  mostly gears are the problem not the shafts. trouble with input shaft/gear and counter shaft/gear,  you have to pull cab and dropbox to work on.  high/low range gears and output shaft can be replaced while in machine.
i was thinking an inframe was around 2000-2500 but that was a while back
head work is pricy because 4 valves per cylinder
dont know much about the front ends, we have never touched ours.
rear end is same as 2wd tractor (like 7080) with heavier axles and planetaries
i say we but the tractors belong to my father, i have done plenty of operating and service work
Edited by CAL(KS) - 06 Jul 2012 at 4:08pm
This page was generated in 0.106 seconds.
