warm weather comming
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Topic: warm weather comming
    Posted: 25 Mar 2011 at 9:47am
Maybe this will warm ya up, think SPRING
C:\Documents and Settings\Rich\My Documents\My Pictures\2010-08-23, fish and boat\fish and boat 020.jpg
Hope it work having trouble loading pic's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:48am
Well that didn't work darn-it
HELP MAYBE......?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 10:25am
Posting Pictures in memory of Barb C.
To post a picture from your computer, first click on  new topic + or post reply/ . Do not use the quick reply box at the bottom of a previously posted topic. At the top of the box that opens is a row of icons. In the middle of that row is a picture of a tree, click on it. A window that says image properties will open, if that window is small, maximize it so you can see everything in the window. Click browse and find the picture on your computer and open it. Click upload and a small window will open asking you to be patient, click OK in the small window. The picture will appear in the box on the lower right side(if not click preview). Check the width and height of the picture. If the numbers are greater than 800 wide and 600 high, the picture will not be seen completely on the forum. You can change these numbers but need to keep the ratio the same between them or the picture will be stretched. Click OK at the bottom and the picture will appear in your post. You can add text to the post before or after uploading the picture. It is easier to insert your text first. Now click post reply or post new topic and you are done.
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 11:21am
We have 9" of new white spring laying on the ground from tuesday's blizzard after 2" of rain on monday. Not an early one like last year!
HD16,917H,185,7050,8030FWA,8050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 12:14pm
Will try this,
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 12:15pm
It worked, had to resize
