Wanted 170 gas engine govenor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Wanted 170 gas engine govenor
    Posted: 02 Aug 2012 at 9:04pm
Looking for a governor for a 170 gas engine . Any help appreciated. Tracy Martin
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 9:20pm
i have one for sale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 10:22pm
Does the housing on a combine engine and the one on a 170 interchange? I was told they are differant.Is all that is needed is governor weights or entire unit? Thanks Tracy Martin
Edited by Tracy Martin TN - 02 Aug 2012 at 10:23pm
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 10:23pm
Just the weights and spring are different, I believe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 10:29pm
Matt, just trying to confirm. I don't have a parts manual on combine engine or I would compare part numbers. Thanks for info. Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 11:13pm
www.agcopartsbooks.com  "guest"...... diff #'s for both spring and weights.The tractor spring has a slug inside to close throttle.I doubt the combine one does because it is adjusted by a screw to set high idle and the carb shaft is pulled on to close it.
 the timing covers are same #.....the front cover is diff
Edited by SteveM C/IL - 02 Aug 2012 at 11:20pm
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 7:17am
 I am pretty sure you can change the weights off combine engine to the 170 weights.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
