wagon gear?
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Topic: wagon gear?
    Posted: 04 Jan 2012 at 9:08pm
Can anyone on here tell me what brand wagon box & gear is pictured here?  Owner can not see any id tag on the running gear.  If its an Electric or Allis gear, what do I look for to tell the difference?  It has the front tie rods like the AC 8-10 ton gear.  He said that it had 6 bolt 15" wheels and that the tip tops on the box were metal instead of wood.  Tires are all dry rotted, but still up.  Even if its not Allis, whats it worth?
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 9:30pm
Looks like it might be a Ficklin box, I'm unaware that AC ever made a gravity flow wagon. The gear could be an Electric Wheel gear, IIRC they made the gears for AC. If it trails good probably $300 to $400. If the tires were good it would be worth more.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 9:54pm
Looks like a 10 ton electric looks like it has heavier hubs than 6 bolt. If the box doesn't have rust blisters $1000 range.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 7:12am
To me much of the value is tires,if it has good implement tires it's worth a lot more!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 8:26pm
Thanks for the posts.  I went and looked at it this evening.  It is a New Idea wagon running gear.  I still have not figured out what brand made the 250 bu gravity box - maybe New Idea as well??  It does have an interesting metal tip-top extension that is omitted in the front.  Maybe it was omitted to enabled an ear corn picker's elevator more room while the wagon was trailing through the field behind it??  I managed to secure this one pic before my digital camera's battery failed.  It has 8 bolt hubs with 12.5L x 16 tires so I'm thinking its at least an 8 ton.  Maybe someone on here will know more from this id tag picture?  The serial number has an 8 in it?  Even though it was not AC, I still liked its character and so I bought it.  Look out wire brush & sand blaster :)
Since I could not get another picture, I looked over the steering & hub assemblies, closely.  In comparison, I am figuring that the running gear was manufactured by Electric Wheel, Quincy, IL?  It's hub & steering assemblies are nearly identical to some 10ton AC gears, like the one pictured below.
This page was generated in 0.110 seconds.
