Valve lapping |
3rd generation
Topic: Valve lappingPosted: 6 hours 58 minutes ago at 8:25pm |
I’m sure this has been long discussed if lapping is needed. I just had hardened seats installed and valves ground. Personally I trust modern machining for a good seal. How many of you still lapped valves with hardened seats?
Joined: 11 Sep 2009 Location: illinois Points: 88797 |
Posted: 5 hours 59 minutes ago at 9:24pm |
always a good idea to get a finish lap.. if nothing else, to CONFIRM it is correct..
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8693 |
Posted: 5 hours 1 minutes ago at 10:22pm |
Can't hurt? When seats and valves are ground/cut correctly it's not needed.
Posted: 3 hours 48 minutes ago at 11:35pm |
HELL NO !! Ask yourself this: do you think GM or FORD for example take the time to "lap" valves and seats after their modern and expensive valve grinding equipment has just mass produced hundreds of cylinder heads a day ?????? NOPE.
