Value of Black belly 7580
RPSallispullinmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RPSallispullinmd Quote  Post ReplyReply Direct Link To This Post Topic: Value of Black belly 7580
    Posted: 18 Jan 2012 at 5:54am
I have a friend that has a 7580 black belly 3500hrs,18.4x38 clamp on dauls tires not to good,3pt,pto,engine has been rebuilt since new,runs good.has a seal leaking at the driveshaft going into the rear.Good overall mechanically.60miles from my home.Thanks for response.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 9:34am
Big four wheel drives aren't all that valuable in most parts of the country simply because the guys who use them a lot aren't interested in a 30 year old machine with no warranty.
I'd value it at no more then ten grand and really, $5 or $6 is still pretty fair, considering you are looking at $4,000+ for new tires.  Sixty miles would be a long drive so you've easily got another thousand in trucking, unless you can do it yourself.
The seal shouldn't be a big thing but carefully watch the drive shafts as they are the archillies heel of those machines, as Redline and I can both attest to.  Still, at the right price, it's hard to beat for horses per dollar.
Allis Express participant
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 12:02pm
Trucking would be no more than $300 or $400. If 60 miles at $4 a loaded mile ads up to $240 plus time to load and unload(45 minutes to an hour). Tires tough, if radials, can be $2000 a pop or more for a good brand.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote RPSallispullinmd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 5:37pm
I ask because I really don't need this tractor but I think I can buy it for around 5000 and it would work good for grain cart that I don't have at this time but was hoping to get one in the near future.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 7:51pm
how big of a grain cart you plan on using?  dad has an eztrail 750 and we use an 8550 on it because it pulls alot better.  it will work.  we unload on the go and the 7580 just doesnt have to torque to speed up and slow down while loading off the combine. now they are nice because you sit up higher than 2wd  and we use ours mostly to pull 36' drill.  just remember you you pretty much have 7080 power but lugging around more iron. as mentioned above drive lines and CV joints are expensive.   still a good tractor though,  5000 sounds cheap to me
Post Options Post Options   Thanks (0) Thanks(0)   Quote RPSallispullinmd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 9:09pm
guys I know the 7580 is a Dog our neighbor had on when new and I drove it back then we had a 7060 at that time and other than wet ground the 60 would out work the 4wd.I just need like around 400bu. cart.
