Using a starter solenoid on a WD45 |
cbuttre835
Joined: 12 Nov 2010 Location: Peytonsville TN Points: 105 |
Topic: Using a starter solenoid on a WD45Posted: 01 Dec 2016 at 2:38pm |
I'm wanting to run my WD45 starter with a solenoid rather than the starter-mount button and lever-rod setup. (Why? Im custon building a dash and just want to)
Can I remove that switch and wire in a heavy lead to a big solenoid? |
C w/ 3rd gear out
D15 II factory 3 point WD (no motor!)(parts for sale!) WD 45 wide front |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 01 Dec 2016 at 2:56pm |
you will need to replace the switch contact lug with a stud so you can attach a cable to it but yes
MACK
Posted: 01 Dec 2016 at 8:57pm |
Find a starter for AC 100 combine, it was made that way. MACK
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 02 Dec 2016 at 10:47pm |
Don't know when I'll get back up to the farm, but I did this to my 1940 C and it works just great.
Don't know if you can tell what I did by this picture..... ![]() |
Ted J
Posted: 04 Dec 2016 at 11:49am |
I'm going to do this to my WD45 also, so when I get up I will get a pic and some description of what I did and send it to you.
Joined: 11 Sep 2009 Location: illinois Points: 89192 |
Posted: 04 Dec 2016 at 1:47pm |
Don't know what TED did, but the original starter has a cam connected to the push rod and the cam pushes the starter contact in... I pushed the cam in manually, then put a 1/4 inch PIN thru it to hold it in place so it could not backoff the switch. Did this on 4-5 tractors.. Only had one that the cam backed off a little and lost contact.. Had to REDO the pin to hold more pressure on the switch. .......... I think I actually had to make a new cam a little larger so I could get the catch pin into place.
Edited by steve(ill) - 04 Dec 2016 at 1:49pm |
Ted J
Posted: 04 Dec 2016 at 6:19pm |
NOW that you mention it steve..... I made a new cam piece so that the cam was larger and kept the starter contact IN ALL THE TIME. Then just wired in the solenoid and used a key to start it. SIMPLE!!
THANKS Steve......my memory isn't what it used to be........be what? ![]() |
