tyres for allis b
keithm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keithm Quote  Post ReplyReply Direct Link To This Post Topic: tyres for allis b
    Posted: 28 Nov 2011 at 1:48am
i have just about finshed the rebuild of my high crop be
and now iam in need of ruber i need the size of the rears and the frounts
i have a set of 19.5x24 0n the rear and there are 3inch spacers under the spindles on the front with 13inch rims
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 6:42am
My B has 11.2x24's on the rear and 4:00x15's on the front. 10:00 was the original number but was replaced by 11.2. You will probably need new rear rims if you go to 11.2's from the 19.5's. I would like to see a picture of the 19.5's on your B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 4:47pm
maybe a misprint ?  I cant see 19.5 inch tires on 24 inch rims ! For a HYCROP i would think you want 28 or 32 inch rear rims. You should have the original 4 x 15 inch tires in front. If you put 3 inch blocks in the front and you want to maintain level, then you need 6 inch bigger rims in the back. So you can go with 28 inch rims with big tires like 12.4 wide, or use the larger rims 32 inch, with a narrow tire like the 9.5 to keep it somewhat level.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 8:21pm
Asparagus special was 8 X 38 and potato special was 7 X 28.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 8:28pm
keith, have you got adaptor plates (spokes) to put the bigger rims on the original cast hubs ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote keithm Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 1:44am
this tractor came to me as a big box of bits the rims came with it may be i should look for a set of rims
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 6:05pm
24 are too small if its a hicrop or cane tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 6:06pm
wrong tractor, right idea
