Turf Tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Turf Tires
    Posted: 30 Oct 2015 at 10:22am
Got a chance to get some turf tires for cheap.  I have standard rims on my 'C' now.  I don't know what size the rims are, but they have 12.2x24's on it.  Will I have any problems with putting these tires on?  They are 16.9x24's...
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 1:48pm
you won't go anywhere very fast in the winter
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 5:46pm
They sounds a little wide, for a standard rim...
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 6:25pm
Shameless is right about winter, I had turf tires on a 230 Massey and as soon as it snowed the tractor went into storage.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 8:44pm
No way a 16.9 is going on a 12" rim. And the 12x24 tire is probably on a 10" rim. You could use tem to trade for some 12.4 or 13.6 tires.
AaronSEIA
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 10:10pm
Get yourself a set of rims and if you don't have fluid,simply unbolt the smaller tires in the summer and switch them. Make sure the bigger tires will clear the fenders.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 10:17pm
Turff tires with chains are AWESOME !!!!  Try it you will like it ...
sandman2234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandman2234 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2015 at 9:29am
Maybe I am missing something here, but I have a bunch of 14.9-24 tires and they are a little large for a C, I would think. However, they are the "oversize" option for a D-12 so maybe it is just me. I have the tires on rims and wouldn't consider putting them on a C. Just my $.02. However, mine are not turfs, alas, R-1 tread.
   David from jax
A proud member of the Allis Express movement!
               Northeast Florida
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2015 at 12:21pm
Your correct. Chains work better on turf tires than field lug tires by far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 5:03am
Well, I went and looked at them and I passed on them.  WAY TOO BIG!!!
After just looking I could tell they would NEVER work on my C.
They are on JD 8 bolt wheels, one has fluid.  One is near new and the other about 30%.  Wants $125 for them if anyone is interested.  Located in La Crosse, WI.  PM me...
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandman2234 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2015 at 12:30pm
Kind of what I thought, when you said 16.9-24, as I have 14.9-24 on my JD and when I park it next to my B's or C's there is no mistaking that those tires are just too big for the little Allis.
  Now if this deal were a little closer...well, probably not even then because I have a set of big turf tires I don't use, and several sets of the 14.9-24 in R-1 with that same 8 hole pattern... so hopefully somebody will have a use for them.
  David from jax
  btt
               Northeast Florida
