TTandem wheel attachment for All-Crop harvester
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: TTandem wheel attachment for All-Crop harvester
    Posted: 30 Sep 2019 at 6:23pm
I’m trying to get mine mounted. Does anyone have any pictures of it on a 60 or 66?
Thanks & God Bless
Dennis
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2019 at 11:51pm
Best I can do is. If you go to Bing images and fill in the what box with "Allis Chalmers All-crop dual wheels " I found pictures that could show you the location and approximate spacing. keep clicking on pics and I found a combine with 3 different angles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 12:06am
next best guess is type in "Allcropharvester" .com, that is the man that has a lot of experience building them. Tom Yasnowski is his name.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2019 at 8:46am
Tandem axle mounts in front of the standard axle. Not the same as duals.
I found an illustration in the parts book for the 72 combine, page 165, on the allcropharvester.com. The dual wheel setup is also shown.
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2019 at 3:50pm
Dennis, If you still need help, let me know, I have a junk unit with the tandem that I can take pics of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2019 at 4:33pm
Thanks Tom, I would like a few pictures of the left side. The right side just bolted right up.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2019 at 8:29pm
ok to be sure you are talking about the header side correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2019 at 8:55pm
Yes Tom, the header side.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2019 at 7:21pm
And dang it I meant to take pics today and I forgot!  Will try tomorrow.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2019 at 9:10pm
The left side tandem wheel mounts to the rear of the standard axle, not the front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 4:36pm
Here ya go. hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 9:24pm
I'll need to post a few pictures of mine. It's a different setup than the one Tom posted.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 8:16am
bummer! leave it to AC...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 9:03pm
Here is what I have. Not sure if it is Allis or an aftermarket, but sure looks like an Allis. Maybe early design?
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 9:35pm
Never saw one like that....
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 9:46pm
Me either! Especially with that stub sticking out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 9:12pm
Well, here it is all mounted up!
Thanks & God Bless
Dennis
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 12:28pm
Looks pretty neat!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 12:54pm
Nice. Does look like a cleaner design than OEM.  Wonder if this was aftermarket..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2019 at 1:15am
The only down side with this design is that you must remove the axle assy. to repair or change the tire.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2019 at 12:59pm
I mounted the tandems on the All-Crop that has the two row corn head. So the up side to this design is that the left side tandem wheel runs in the center of the row. The Allis or Common design would put the wheel right on the row.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2019 at 3:11pm
With the corn head it may be different, but what I like about having tandems with a grain head is the tongue floats off the ground, making hook up and manual rolling of the combine easier.
I have access to two parts machines with the regular Allis tandems, but they are about 110 miles from home, without wheels, with the axles half buried, and big trees through them. Not sure if it's worth it to dig them out to remove the tandem attachments or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2019 at 3:52pm
I would pull them off. They don’t make them anymore and when they’re gone they’re gone.
Thanks & God Bless
Dennis
This page was generated in 0.219 seconds.
