Ts500 work on d19 tractor
D19Dillon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19Dillon Quote  Post ReplyReply Direct Link To This Post Topic: Ts500 work on d19 tractor
    Posted: 26 Dec 2022 at 11:13pm
Looking for any info if a ts 500 front loader work on d19 and mark herny IV back hoe work also
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2022 at 7:03am
Any of the implements you are referring to never fit a D-19, that I am aware of. Just D-14-15-17.  The D-19 side frames width are the same as the D-15 and D-17. The side frame length on a D-19 is the same as a D-17 diesel BUT, the D-19 grille/grille shell stick out forward another 3 or 4 inches. The D-19 has inboard final drive gears with a straight axle to the wheel, versus outboard final drives with a drop axle. So, I can't imagine things aren't going to work as-is in that area either. Wheelbase is also longer on the D-19 chassis. I'm sure with a torch, welder, chop saw and some bloody knuckles, you can make it work somehow.
