Tranny Oil D-17 (Series II)
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Topic: Tranny Oil D-17 (Series II)
    Posted: 02 Jul 2010 at 7:37pm
I'm going to change all the fluids in my new (to me) D-17.
The manual says: "Use only a special transmission oil merchandised by your
"Allis-Chalmers" dealer".
I assume that means "expensive".
Is the D-17 supposed to use gear oil in the transmission like the WD-45 or a modern Hy-tran oil.
I guess when I drain it I'll see what the prior owner used but that still won't
tell me what is correct.
Thanks
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 9:13pm
Brian, I believe you can use Hy-tran in the tranny on both the WD45 and the D17.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 9:58pm
Allis 821 spec is met by most all hytran fluid you can buy nowadays. Farm and Fleet, TSC or Wallyworld.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2010 at 10:12pm
The shop manual says use sae 80 EP, but I have heard many people use the universal tractor fluid in the trans with no problems. Todays oils are far superior to what was available when the tractor was built.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 8:45am
Thanks guys!
