traction booster line |
Acdiesel ![]() Orange Level ![]() ![]() Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2574 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Oct 2016 at 4:56pm |
am I safe to assume that the 1/8" line that goes to the traction booster gauge has full hydraulic pressure on it.
thanks dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24405 |
I'd assume that...it's a STEEL line ..good for 5,000 PSIso do NOT use copper or uluminum or plastic.....lol
Jay |
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Yup, Full hyd. pressure . It is just a hydraulic pressure gauge with a different painted face, nothing special.
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2564 |
Yup. I have one off of a WD that I'd sell if you need one.
AaronSEIA |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8512 |
the guage doesn't help you do anything better than without it.Good for amusement but what you feel the tractor doing is your best feed back.
thanks for the conformation!
restoring my dads d14, steel line was questionable so i want to replace.
JimIA ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1983 |
Tube is NLA from AGCO, might be some NOS around yet.
I like having the gauges working. Even if you are not plowing they are good to have to help diagnose the hydraulics now and then. Just an FYI the gauge measures the pressure on the lift cylinder to let you know how much of the implement you are carrying. Jim |
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Go to NAPA and buy a brake line to replace it. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8452 |
I always wondered what it did.
Dale D ![]() Bronze Level ![]() Joined: 06 Oct 2021 Location: Michigan Points: 3 |
I am trying to restore my father's old D15 Allis chalmers. The 1/8 inch line that runs from the traction gauge to the small square block is bad I need to replace the line also the block that it attaches to might have to be replaced. I have an owner's manual and a repair manual but I cannot find those particular parts. Where would I go to order those parts.
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1021 |
I got one from AGCO a few yrs. back for a D17. Had all the correct bends. Seems it was around $100 bucks.
