Torque settings on bits of a b
2011dandd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Topic: Torque settings on bits of a b
    Posted: 12 Feb 2019 at 12:36pm
Hi guys
Wondered if someone could so kind as to help me out with a few torque settings and oil types etc for a 1947 b. I do not have a manual.
What are the torque settings for the oil pan/ sump bolts?
Front wheel hub castle nuts?
Rocker head bolts?
And the oils reservoirs on the rear wheels?
What fluid goes in the rear wheel/ axle reservoirs?
What are recommended tyre pressures? Does no work just take the kids for rides
Cheers
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2019 at 4:01pm
On behalf of Gerald, if there are specs, you should find them here:
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2019 at 4:37pm
many "generic" bolts don't have a torque listed. Most guys who have been around forever just do it "by feel"... you can get a "generic" torque sheet for  grade 5 SAE bolts and use that as a good reference.. Only bolts that really need "torqued to spec" would be inside the motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2019 at 4:41pm
here are MAX values for each grade of bolt.. Most EXTERNAL bolts would be a grade 5 max.. SOME ARE ONLY GRADE 2......... This chart gives a "grade 3" which is not common, but might be a good value to use on many random bolts.. you don't need to stretch to the MAX.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2019 at 6:41pm
I'm sure there are engine bolt torque specs and ought to be some for transmission and wheel bolts in the manual I have on line. There are a couple pages of specifications at the beginning of the B section.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2019 at 3:47am
thanks very much for the help and the replys
unfortunately the manual wont load, could anybody send me a copy via email please?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2019 at 6:17am
Sent, check your email.
This page was generated in 0.083 seconds.
