Darn excited ( got a 190xt)
Taylor in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Taylor in Indiana Quote  Post ReplyReply Direct Link To This Post Topic: Darn excited ( got a 190xt)
    Posted: 30 Dec 2014 at 7:46pm
Hey guys, this might be a pointless post but seeing as I don't have any tractor friends in real life I just had to vent to some people who understand my orange fever, I went a looked at a 190xt last night a buddy who is a equipment jockey( and bleeds green) picked up, he put a head gasket in it and that's about it, it's got 3000 hours on it, paint is faded but she is straight as an arrow, all gauges and lights work etc dent free grill with emblems. The older gentlemen he got it from just stoped farming with it this year and has been well maintained. So I picked it up and let's just say I got the friend price. He is about to deliver it here soon as I type this and I just can't help but be like a kid on Christmas morning. The price was right and I wanted a factory 3 point as I have a aftermarket on the D17. This is the first tractor of this size I have ever been around, so I guess I'm just looking for experiences, do's and don'ts. Really anything you want to say about a 190xt a newbie should know.
Thanks! I will get pics up after work tomarrow! Taylor
1941 B 1957 D17 1968 IH 3514 Early 190XT Gleaner F
Randy(Mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy(Mo) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 7:53pm
Congrats, they are really anice tractor! One owner, straight tractors with original paint I presume. That is a great new year present. Enjoy
Mo Allis Club member
BPM75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 8:12pm
XT 190s are great tractors, probably one of my favorites. Sounds like you've already bought it but a couple things to watch out for on 190s, 1. Trans jumping out of gear, 2. Power director operation, 3. Rear ends weak on early models. All of these can be costly repairs other than that they are very nice tractors to operate. Good luck and enjoy your new orange.
59 D17 gas nf, 66 XT 190, 69 220.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 8:13pm
If it's a diesel, you are going to love the fuel efficiency of it. If you plan on doing much PTO work with it, get used to using the power director clutch. I have a one-ninety gas and an XT diesel and love em both. Good luck with it! Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 8:13pm
Oh yea post some pics when you get a chance we all like pics of orange lol.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 8:56pm
Glad for you Taylor !! I would pick a 190 if I had to pick there my favorite
      IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Taylor in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 9:26pm
Well i just came in from driving it around a bit, i am struggling to figure out the PD High and Low seem to work, but i don't understand what the point of pushing the stick down is? how do i lock it into high or low? I was thinking it was like the D17 and have a positive snap too it but the lever seems to return to N, but i do have a positive engagement of High or Low when i push the stick, the lever just doesn't stay.
Besides that the only thing i noticed in my brisk 15-20 min running around the barn yard/ letting her run and checking her over with a light was the amp gauge goes up to 40+ when above half throttle, the shaft with the "on/off" cable on the IP leaks, the tilt steering doesn't hold(which isn't that big a deal as im a short and small guy)
She fires right up and seems to run nice, smoother than the 17 gasser.
I figure if i need to put a chunk of money into the IP i will still make off alright...if its a O Ring or something like that even better Wink
Heck its even got a full tank of diesel.
Thanks, Taylor
Edit, also, is it correct to have a key and a push button for the starter? Or a mask to cover up an issue?
Edited by Taylor in Indiana - 30 Dec 2014 at 9:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 9:45pm
Squirt some oil down at the base of the Power Director lever. It has to come "up" to be able to lock in low-neutral-high. Maybe the spring is broken ? I doubt it.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 9:50pm
The push button is standard on the diesels that I know of. If you take the key to the right into the spring loaded section of the switch, you ought to hear a relay click and that ought to be the intake manifold heater that is a cold starting aid. Do not use it conjunction with ether as an explosion in the manifold is likely when the ether hits the glowing element on this electric that looks like a spark plug screwed into the intake manifold. I'm sure you will like the 190. I totally enjoy every feature on mine, and it is the best tractor made to over the front. The Hydraulics beat most from that vintage if the pump is good, steers good brakes good. Just a fine machine. try to talk to the man who owned it before, he will be glad to know someone like you got it. Buy a manual and read it. Do not grind the gears when shifting. Sounds like some WD 40 on some of the linkage might help too.rw
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 10:09pm
Mine had a voltage regulator stuck when it did that kind of crazy over charging. I put an electronic Voltage Regulator about the size of a small match box on the alternator and as a bonus it turns the field coil off when the alt stops turning so no more dead battery if I forget to turn off the key when I kill the fuel. The oil pressure light comes on generally after I had dismounted the tractor, but it takes it a while to run the batteries down. And as an edit I should have said to SEE over the front.rw
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 10:24pm
congrats! they are nice tractors!
MoPete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2014 at 8:58am
I have a series iii XT and it has been a solid tractor. Very forgiving of my inexperience. Congrats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2014 at 9:56am
Bushings on the linkage below your right foot and into the outside of the tranny case; when they are worn, they keep the PD from engaging fully and staying engaged. Cheap fix, just takes a bit of time as the "cup" type bushing can be a stinker at the tranny housing. Sounds like it is currently engaging but you have to hold the handle in-place for high and low right?
With tractor off, push the PD handle to the low side while standing on the right side of tractor and looking at the linkage. You should be able to see that the worn linkage bushings are not allowing full engagement. Push the piston rod the last little bit and she will be fully engaged and stay engaged. AGCO has bushings, I picked up mine from Sandy Lake and she "snaps" like new now.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2014 at 12:07pm
Good find -- great way to start off the new year -- a new tractor, cool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MoPete Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2014 at 2:06pm
wow. Thanks! Been holding mine in with a bungee strap for years! Just never reached the top of my priority list.
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2014 at 5:39pm
congrats on getting a mighty One-Ninety! It is probably my all time favorite tractor! what do you plan on using it for?
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2014 at 11:51pm
turn the key and push the starter button.....my 220 is the same.No "mask".
