this isn't good
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Topic: this isn't good
    Posted: 30 Dec 2014 at 1:22am
ooops, what happened?
been there done that, not doing it again...
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 1:26am
looks like it crystalized!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 1:27am
looks like it was greased!
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 6:33am
Did the needles survive?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 6:48am
Wasn't tempered correctly and became brittle is my guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 6:54am
Always thought it was 'wrong' to bend a steel rod 90* and think it'll hold up to a zillion hours of use. I know it's cheaper/easier than welding  but...... when it breaks it always happens to the farmer, in the filed NOT the bean counter in the head office !!
I'd repair by welding the 'rods' at right angles, extending the horizontal one about 2", welding triangular 'gussets' to both side of the rods. Pretty sure it'd outlive me!!
jay
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 7:35am
Don't know what caused the brake -- be sure to check and see if the needles are OK -- may be able to weld a fix as was mentioned.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 3:51pm
just broke the brake rod and sheared off the shear bolt at the flywheel. Not sure how, but twine got tangled on bill hook, not sure if you can see it in photo or not.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2014 at 5:19pm
Is it possible the shear bolt on the needle yoke is too hard strength? Looks like it would have sheared it before it broke the arm. I thought that was the reason it was there--to prevent just such a failure. By the way what model baler?
Edited by Ky.Allis - 30 Dec 2014 at 5:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2015 at 3:04am
It's a 302 Ky. Allis. I thought the same thing but if you look at the first pic. you can see a small block under the cotter key, I think the needles were on the return swing so the block held the arm in place and the shear bolt had no effect on it. the ram stop did it's thing though.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2015 at 9:21am
if twine and/or knots are hanging on the bill hook, check the knife arm, their supposed to lightly drag on the bill hook, this is how the knot gets moved off the bill hook. the way I check is take the bolt out holding the knotter to the baler frame and rotate the knotter assembly up, watch your fingers, then watch as the knife arm moves across the bill hook
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2015 at 9:39am
Flint23....I should have that link.  Thanks...Dale
Orangereborn
Dale Schafer
964  192nd Ave
New Richmond, WI 54017
715-247-3079
715-781-2055
Orangereborn@hotmail.com
This page was generated in 0.077 seconds.
