off color IH question
orangepower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangepower Quote  Post ReplyReply Direct Link To This Post Topic: off color IH question
    Posted: 20 Mar 2010 at 9:36pm
looking a little at a IH tractor at a upcoming consignment sale, how do you tell if the ta is good, or do you find out its out at home when you put it under a load. maybe work both sides of the ta with the brakes pushed down to see if it will slip?
TimOk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimOk Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 12:05am
What model IH?  Some had mechanical TA with ramps and rollers. These were a pulling TA only. Meaning NO Hold Back in low side (free wheel down hill with disastrous catastophic failure if it over sped too much). One check is to put TA in low side ,trans in upper gears and stand on brakes to see if it slips. Ultimate  test is with a plow or disk and see if it slips in low side.HTH  Tim
Tim from the Rocking TJC
This page was generated in 0.299 seconds.
