4 wheel drive C
Sam (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam (WI) Quote  Post ReplyReply Direct Link To This Post Topic: 4 wheel drive C
    Posted: 24 Oct 2014 at 8:48pm
Anybody know about this tractor? I see they mounted a second set of final drives for the front axle but how would you steer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2014 at 8:54pm
Either the front axle pivots, or you skid steer.The Power Horse was based on a B but turning took away too much power from forward motion as the outside wheel would speed up when stopping the inside wheel.
http://www.farmcollector.com/tractors/power-horse-tractor.aspx#axzz3H7MYJEop
Edited by CTuckerNWIL - 24 Oct 2014 at 8:58pm
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2014 at 8:59pm
That looks kinda like what a model H would be.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2014 at 9:27pm
Just thinkin out loud.....would be fun to make one and use it to skid logs from out back up to the yard. But then again...might be a little weak on the engine to skid if its turnin 4 wheels.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2014 at 9:40pm
does it really have another set of final drives ? You need the bevel gear housing to drive the finals. That would be quite a bunch of mass under the engine oil pan... I don't see that. I would guess it has a front axle from a 4 wheel unit and that would include steering ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2014 at 4:38am
Google powermaster or H, this unit was made for a couple years.  The original concept was a tractor that you could use to pull horse drawn equipment, it had control reins that you used, from the seat of the implement.  It's main drawback was weakness in power in the turns...
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2014 at 5:50am
Where did you take the picture?  I'm sure this tractor is in the George Nesbitt collection here in Ontario. He bought it this past summer. I have more detailed pictures on another computer. It is supposed to be the prototype 'H' but I have my reservations.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2014 at 12:29pm
Since it has no steering wheel my guess would be skid steer. Seeing the C drawbar out the front to hold the front of the engine it more than likely has a C final drive set in backwards and powered from the power take off using gears and roller chain. Looks like a CA torque tube. Of course anyone can guess anything and be totally wrong. Be fun to see up close.
TerryMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2014 at 6:57pm
Home built tractor not the allis model h
It drives off the pto
It is neat and I respect the work the person put in. But it is not an allis chalmers prototype.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2014 at 8:37pm
Terry you are correct. The front drives from the PTO and the 'C' rear in the front is driven through the PTO. It is a skid steer but by braking not clutching. I didn't think it could have been the 'H' prototype either. It is not built as the prototype was discribed in Norm Swinford's book.
Edited by Calvin Schmidt - 26 Oct 2014 at 6:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2014 at 4:35am
That certainly explains it, does it have the serial # stamped on upside down?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2014 at 5:48am
Tractor was sold at an Auction in June, 2014 in IN - $20,000
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2014 at 6:17am
20G !
Wow ! for 1/4 of that you can have both my Bees and the C and make your own !
As much as I'd love to build one my 'job jar' is overflowing, my 'todo' list is 3 pages long and my hernias and back getting too old to haul big heavy things this week !
Sure would be a nice project though......
Jay
North of the 49th
kinda dark at 7 today,sigh....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2014 at 6:24am
It does have a serial number 24xxx on the main tractor. On the front, the axles and final drives are rotated 90 degrees forward and the drive is in through the PTO end. I did not check the front transmission for a serial number. I'm not familiar enough with a 'G' but I know the the engine is on the PTO end of the transmission so I don't what internal changes would have to be made to have this tractor drive both axles in all the gears.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2014 at 7:26am
For the B & C there's a shaft that is driven from the front of the transmission, that goes through the transmission to drive the PTO. The G uses that shaft to drive the tranmission.
Dusty
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2014 at 8:00am
Wonder what happens when you put the driving transmission in reverse ?
The PTO doesn't change direction, so front wheels would still be driving forward !!
I guess just shift PTO out of gear.
Gary
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2014 at 12:39pm
That's right It went for 20 G's. I was there at the Gayhart auction and I think it went to Canada....I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2014 at 5:51pm
Might have the spider gears welded up to lock up both axles...
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2014 at 6:03pm
If the axles were locked together, how would you turn by braking ??
Gary
arnfinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arnfinn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 4:32am
Hello, I found some additional pics when browsing this nice project.AC_1.jpgAC_2.jpgAC_3.jpgAC_4.jpgAC_5.jpgAC_6.jpgAC_7.jpgAC_8.jpg
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 6:36am
looks to me like it still needs some work, but neat anyway.
notice the gearshift under the engine.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 6:49am
great, it's snowing, nothing to do... but think..gee I have 2 'extra' D-14s here........
wonder if that's been done before...
Jay
I need a job, too many ideers,too little time !
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 8:27am
Wonder if you could do this with CA axles/housings on both sides so you have the clutched axles and would actually have steering clutches? Not sure if you could spin the CA axle housing around and use it on the left side too? Then you would also have to weld the diff so it would keep going when a side was disconnected. That would be such a cool project. Useful; probably not, but would be cool.
Edited by cpg - 12 Jan 2016 at 8:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 9:33am
Ca's can have a hand clutch on the left side. If you weld the differential, you couldn't steer it. Just adding a hand clutch on the left and keeping the right side clutch would allow either wheel to be powered or both.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 9:40am
fellow in southern Iowa had 2 wd45's hooked together, pivoted in the center like most bigger 4x4's do. I think I've seen them before. That one looks like it would not turn very short before the tires came together
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 12:30pm
Who can post a picture of a UC set up like this? I might be fun to see them side by side.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 12:42pm
I have toyed with building a 4 wd out of a d15. Either adding a front assist or building an articulated setup. My train of thought was to get a stronger front end which would make a better loader tractor. I always thought the 4 wd tractors with the same wheels front and rear look unstoppable to me. I never got beyond toying with a few design ideas. But I love seeing photos of stuff like this always thought it was too bad that AC never went anywhere with the 4 wd concepts back in the early days. Seems like if you could put a shuttle clutch on each side you wouldn't loose too much power in a turn I mean skid steers are very useful tools. But I couldn't really figure out how you build the mechanical setup to drive each side when the tractor was really designed to drive across and axel. Seems like an artulated design would ne easier to build out of d serries parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 12:46pm
I did wonder if you could put a hydraulic motor as the input to the final drives and build one that way but I figured the torque required at that point would be too high. But if you could do 4 hydraulic motors one on each wheel controlling it would be easy.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 4:51pm
I see 2 levers sticking up.---look just below and on each side of the throttle tower!---can anyone see what  they hook to and is it on the front or rear end?? thanks; ac fleet
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 5:05pm
anything is possible with time and money!, remember the UC done by Thompson?
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
This page was generated in 0.281 seconds.
