Dads B
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Topic: Dads B
    Posted: 25 Aug 2014 at 11:35am
could someone estimate the year on this ? it was purchased new by my grandfather with the adjustable front to cultivate tobacco. dad had to trade it off on a new hay rake in the early eighties. now I am more determined than ever to try and locate it.
Edited by EricPA - 25 Aug 2014 at 11:57am
Life is tough,but it's tougher when you're stupid. - John Wayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 11:43am
having trouble posting pic at work, will try later
Edited by EricPA - 25 Aug 2014 at 11:52am
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 2:38pm
It is electric so it's either late 40s or early 50s, I don't guess you have the serial number do you?
1950 B, 1952 pulling wd, and 1954 wd45
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 3:42pm
It's a 50s model. 5 bolt rear and adjustable front end.
Prolly be hard to find the same one. But to find one identical to it. That would be very doable.
Edited by AJ - 25 Aug 2014 at 3:44pm
Can't fix stupid
sandman2234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandman2234 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 4:48pm
Are there any non-factory things about it that you remember that would set it apart from just another B? Scratches, changed bolts, anything?
   David from jax
A proud member of the Allis Express movement!
               Northeast Florida
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 7:49pm
Yes, my brother and I will know it when we see it Wink
ScottMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottMN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2014 at 11:08pm
It appears from your picture and using the parts book the following information might help in determining the year.
Starter
(bottom location of switch and rod on starter was used till late 1950 -parts book shows B113778)
Taillight
under seat? (taillight was mounted on left fender in late 1950 at B113894).
Footbrakes
(I do not see a handbrake levers) footbrakes started mid 1941 at B52718.
The optional Standard Adjustable front end started in 1940.
So given the above, your tractor could range in years from mid 1941 to late 1950. So given this range in years, unique features about your tractor would help. As others have stated, remembering welds, dents, etc. may be helpful in identifying your tractor.
Good luck in finding your grandpa's tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandman2234 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2014 at 5:49pm
Well, if your going to have to "see" it to know it, and you need to know where it is, or who bought it, then I would start by advertising for anyone who purchased a B from them, or know of someone who did. That list is going to be long, and full of pot-holes because your going to have to chase a bunch of tractors in order to find the right one.
  Another problem with this is how far your going to have to travel in order to chase down some of the leads. Anything that shows up around here in your search, give me a shout and I will go take some pictures of it.
   Do you have an email account you want us to send pictures of any B's that fit this description so that you can preview them?
  David from jax
               Northeast Florida
