190xt diesel
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Topic: 190xt diesel
    Posted: 26 Apr 2014 at 2:00pm
Took home a 190xt diesel series 3 a few weeks ago. It has a lope to it at idle. It's not as bad after it warms up but still doesn't sound right. It runs great at higher rpm's. I changed all fluids and filters. No change. Also the pto doesn't stop when you disengage it. It's a 1000 rpm pto. Any thought?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2014 at 5:03pm
usually a surge or hunting idle indicates the flex ring in the pump is completely gone, and the weight carrier is just slapping back and forth in the slot for the rivets. Once a load is applied, it will smooth out. Pretty common thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2014 at 5:29pm
Okay is it hard to replace or do I need to send the pump in. I'd prefer not to until field work is done.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2014 at 7:05pm
I think you need to send it in. It may not last the season.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2014 at 8:34am
It requires sending to a qualified pump shop for best results. It will probably get you through the busy season, then you can pull it off and get it rebuilt. Guessing on the pto that it's a hydraulic clutch, and it has either a linkage issue, or the pto clutch is smoked and welded together.
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2014 at 8:50am
I would say ED's on the right track about the pto if it's hydraulic but it could also be the brake may need new seals, does it turn at full speed or just slowly turning?
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2014 at 9:33am
Check timing too....esp if its new to you tractor, a 190 in the shop the other day was sitting on 11°
Slade
johnea4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnea4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2014 at 8:38pm
My XT lopes at cold idle also, i thought this might be the problem.  But it started doing something new yesterday:  under load (discing) it gradually starts "missing" and losing power.  if i turn it off and restart it does fine for a while.  is this a pump problem also or fuel supply problem?  I haven't had time to blow the lines out yet to see if theres crap in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2014 at 8:42pm
Same problem. The broken flex ring material is plugging the return fitting and return flow from the pump, causing the housing pressure to rise, until it finally just kills the engine. Very common problem with the Roosa pump. Time for a routine freshen up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnea4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2014 at 5:51am
Great.  Like ironac, i wonder if it'll make it through the season.  Better call an injection shop today...  Thanks for the advice.
gerkendave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2014 at 6:56am
My 190XT seems to lope at a cold idle but when warm it smooths right out. I always assumed it was maybe turned up a bit causing it to lope a bit at idle but maybe not? Am I looking wet the same problem here?
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2014 at 7:40am
my 6080 does that when cold. Is it the same problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2014 at 7:51am
Very likely. Most of these older tractors that have not had the pump serviced and updated within the last 20 years or so, will start having problems with the flex ring. Today's fuels seem to attack it faster than the old days. Just something to be prepared for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2014 at 9:25am
What will happen when the flex ring fails completely? Will it just not run or.will it not respond to throttle input? What happens?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2014 at 9:58am
what a lot of people's fix is to knock the ball out of the return, and it will keep running. The problem is the flex ring is a cushion between two metal components. Now the cushion is gone, and then the rivets saw themselves into the end of the slot, putting metal filings in the pump, and eventually sawing the rivets completely off, resulting in potential runaway condition. Plus, knocking the ball out of the top fitting will allow all the particles to go right to the tank haunting you with supply issues later down the road.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2014 at 11:06pm
When I'm into one I always install the updated, enclosed weight retainer to help eliminate the flex ring problem. Only down side is you have to re-time the IP because you loose your timing mark when you replace the weight retainer.
Another reason is I have a hard time installing a new flex ring over the rivets on the old retainer. They probably have a tool for it that I don't have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 8:11am
there is a tool to put the timing mark on the retainer. And the tool for installing the flex ring is a small snap ring pliers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 9:56pm
I just use one of those cheap metal engravers to put the timing mark on. I've tried the snap ring pliers for the flex ring but it's still a pain.
Andy190xt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy190xt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 6:10am
Hello, I am new to this forum. I can see this post was from a few years ago but I thought I'd ask anyway. I just bought a 190xt and I'm having this surging problem. The injector pump is said to have just been rebuilt. I was wondering how likely is a runaway? And what to do if it occurs? The air supply would be hard to cap off in a hurry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 6:34am
If the pump has recently been gone thru, I'd be more concerned about dying in a car crash than the engine running away. If for some strange reason it does, you shift it into 8th gear and hold the brakes really tight and kill the engine. So, just to be prepared, make sure your brakes work well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy190xt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 7:26am
Okay that makes me feel a bit better about that. I've blown out the fuel lines, flushed the tank, cleaned the sediment bowl, and replaced the filter. What would you suggest I do now to track down this surging problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 8:01am
First thing would be set the low idle at 700 to 750 RPM. Slower than that can cause rough running in some cases. With the sediment bowls (there are 2) removed and fuel valve turned on, there should be TWO STREAMS of fuel flowing out. If not, there is a blockage in the inlet of the sediment bowl assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy190xt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 1:40pm
Okay. I'll give that a try. The one sediment bowl is on the driver side so to speak under the tank. And ware is the second one? Right behind the injector pump? Does it have a little wire clip holding the top on? Also have you ever tried any of the injector cleaners that you buy at the auto parts store and dump in with your fuel? How do they work?
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 6:17pm
I you are looking at the fuel tank one is on the far left side and one on the far right right behind the 3 point arms. The spring clip and plunger you are referring to ahead of the injector pump is the fuel primer to prime the pump and injectors if you run out of fuel
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 6:19pm
I've tried the injector cleaners but, can't say they helped or not
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 7:18pm
What injpumpEd hasn't said in this thread, is that he has an excellent reputation in his diesel repair service. He rebuilds pumps, injectors, and I'm sure a lot more, that he can tell you about.
Knock on wood, I've had no diesel (pump or injector) issues for a while, but when I do, Ed is the guy I intend to call.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 8:36pm
I will second that,Ed is the man. I bought a 190xt last year. Ed did mine about a year ago and what a huge difference. I recently had a similar situation with a slight surge bailing hay. Then, she failed to start the next day. Installed a new fuel filter the next day, bled the filter and my issue went away. Fuel bowls were clean but apparently there is dirt in the fuel tank. So glad the filter did its job, only 50 hours on it. I couldn’t be happier with his work. Turn around time was excellent.
This page was generated in 0.104 seconds.
