WD Engine question
Jim H(CO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim H(CO) Quote  Post ReplyReply Direct Link To This Post Topic: WD Engine question
    Posted: 11 Feb 2010 at 10:58am
Was out doing some snow pushing a couple weekends ago and while doing some light back dragging with the loader, the engine lost power.  I have a 400 series loader on the WD which uses the pump on the crank shaft pulley.  Oil pressure still in the 15-20# range, but the engine is no longer idling and running like it did.  I would appreciate any suggestions as to where to start looking for the power loss reason.  When I say it isn't running like it did, it doesn't idle smoothly and when I increase engine rpms  with the  throttle lever, the engine doesn't run as fast as it did before.  I can increase engine rpms using the fuel control rod into the carb, but it doesn't hit the same rpms using the throttle.  I was wondering if the governor is the problem or are there other things I need to deal with?  Thanks for your help.  Jim
LarryWC In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 12:45pm
Boy it sure sounds like somethings up in the governor,,almost sounds like somethings stuck (or came loose) and not letting it operate to its full potential!
www.allischalmersmuseum.com
Mike(SEIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(SEIN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 2:56pm
Sounds like it might have stuck timming advance weights in the distributor , Just a thought.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 3:40pm
Had the weights fly off a D-17 govenor one time and it caused alot of damage. Id check em out before I ran it too much.
This page was generated in 0.297 seconds.
