How big a bush hog?
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Topic: How big a bush hog?
    Posted: 04 Feb 2010 at 7:12am
I want to get a bush hog for my WD45 this year. A friend of a friend has a landing strip he wants me to keep cut for him this summer. How big can I go (5',6' or??) without making it to hard on the 45?        Thanks, FredinInd
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 7:23am
Going with a 7 foot would be nice so you could mow outside of the wheel tracks for a cleaner cut but I think a 7 foot would be too much for it.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 7:48am
If you are mowing a landing strip a 7 footer would work fine. If you are going to mow tall grass/weeds a 6 footer would be more appropriate. For runway work you might want to take a look at finishing mowers to get a better job.
My son and I hooked my 7 foot Landpride finishing mower behind a WD last summer, it worked just fine mowing lawn. I wouldn't want to try it on foot tall grass in a waterway.
Randy(Mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy(Mo) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 7:57am
I pull a 7' with a D-15 with ease as long as you are not cutting right on the ground through thick fescue, I have also used a 10' with a WD45 with no problems if you cut it several times a year
BillyL(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillyL(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 8:23am
I mow a 2 acre pecan orchard with a 6ft bush hog finish mower behind our WD45. It is all centipeed grass and the tractor doesn't know the mower is behind it. I would think you could go several feet wider with no problems if you are mowing grass. If its over grown I think you should still be able to handle a 7 footer. However when you get above 6ft you can quickly spend more on a mower than you could buy the tractor for.
Billy
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 8:31am
We use a 10 foot behind a 45. We cut tall grass and weeds 1 time a year and it handels it fine in low gear. When you get in heavy thick stuff use the hand clutch and ease into it.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 2:29pm
I had a 7' behind my 45 and it will mow anything, no problem, the govenor will open up and clean the carbon out.
Tom
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 3:06pm
I have a 53 WD and have used a 7 foot pull behind brush hog for over 20 years. Cut waist high grass, weeds as high as the top of the muffler, buckbrush, small sprouts, honeysuckle, etc.  Normally run in 2 nd gear.  If really heavy, go to 1 st gear or use the hand clutch to slow down.   Make sure brush hog shear pin is correct size or slip clutch is properly set.  I stripped gears out of tractor PTO drive when accidentally driving over a roll of fence wire a couple of years ago..........not cheap to fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 3:31pm
well, I guess I'm going to be looking for a 7' bush hog. If a WD can handle one, I guess a 45 could too. If anyone has one they might want to part with, let me know, we'll talk.
Thanks for all the input.  I'm in the NW corner of Ind. 219-221-8888 or 219-916-1700.
            Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 4:17pm
A 5' mower in 3rd high on my D17 doesn't know it's back there, even with 3 rows of corn stalks. 2 rows and 2nd gear was a workout for my CA. Shouldn't have any trouble finishmowing with a 7'.
WEL(TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(TN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 4:40pm
Be carefull if you plan on lifting a 6 or 7 foot bush hog as opposed to a pull type. The front end gets very light on the WD45. Think about weights for your front end.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 5:52pm
I run a 7" mower on a WD45, I mow the yard in 3'd gear will do a great job.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 6:01pm
I use a 10' Woods offset. Handles it great in second....usually in grass less than 1 foot tall though.....
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 7:52pm
Sooo, me using a 160 with a 6' bush hog to clear a lot overgrown with small saplings up to 2", broomstraw, honeysuckle, and blackberry briars might have been a little harsh for the tractor? Ooops. Tractor didn't seem to mind, bush hog made a few funny noises a couple of times, but no immediate damage. I mostly backed it in with the lift up, and then eased down on top of everything. On the smaller stuff I just ran through in first on the high side.(I think, been a few years back). Was really impressed with the power the tractor had. Hardly even got the smoke rolling.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 8:39pm
Dream it takes quite a load to get those Perkins to smoke.....Fred I think that you will find that the 6' will give you the most bang for the buck! That is the most common size and the cheapest per foot that I have found.  I gave $1680 for the last LandPride that I bought.  I think the 7' was around $2200 and the 8' is over $5k! I bought a used JD MX8 (8') and use it on my 175D and need fluid and weights up front to keep the front end on the ground. It can be a load in alfalfa, knapweed or swamp grass.  I also bought a Brushhog brand 7' and it just seemed too bulky, long and hard to control around rocks so I sold it.
D17SIV with the 7 foot....that is a big swing for a single spindle.  The 8' uses two spindles @ 4' each.
Edited by Eldon (WA) - 04 Feb 2010 at 8:51pm
ALLIS EXPRESS!
This year:
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 8:48pm
   will handle a 12' bat wing on a runway mowing once a week  no problem 12-15 hp. per section  we have B mowing with a 6' in 2nd gear
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 9:19pm
We used to run a 6' behind a 5050, no load at all, unless you stuck it in foot tall bermuda in the ditch.  I have a 7' for my 7060. You've got to listen for to clutch to slip, because 6' kochia at 7mph won't pull down the 7060.  I'd go with 7 or 8' 2 spindle mowers, not all the way to a finish mower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 10:21pm
6 foot would be best match I believe.I don't think drive system for PTO was designed for a heavy load.Need to constantly check bolts holding transfer case under trans. where pto is connected.I have had these loosen while bush hogging with the WD45.Tractor has plenty of power but the PTO can't keep up.
