D17 Flywheel Depth
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: D17 Flywheel Depth
    Posted: 21 Jan 2010 at 10:39am
I tried to search and couldn't find the reply. What is the proper depth to grind the flywheel on a 226 gas. Someone posted it after I had the flywheel turned in the D17D that I fixed last summer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 5:49pm
Can we still search the old forum. The posts for the flywheel depth were on there.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 5:53pm
cant search the new forum to well let alone the old.
MikeB (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeB (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 6:18pm
Brian are you talking about the flywheel clutch face? I have the 170/175 service manual handy and the flywheel for the 226 gas engine is the same as a D17. If so that face can be ground .0625" maximum. The dimension from clutch mounting face to clutch face surface is 1.437" +/-.005". From clutch face surface to pilot face is 1.157"+/-.01".
