Always keep a bucket of water at welding area
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: Always keep a bucket of water at welding area
    Posted: 03 Apr 2013 at 6:18am
Yesterday I was moving some things around with my skid steer, when the muffler tail pipe fell off. I thought I would just go around the the front of the shop and weld it back on. While welding in a tight spot, I thought I smelled smoke. Down in the belly of the machine, there was some leaves and old oily stuff under the engine. Before I knew what was happening, I had a pretty good fire going on. Luckily, I keep a gallon of water under  the welding table. That got it slowed down until I could get the water hose out. I think I may start keeping a bigger can of  water handy.  Dave.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 6:32am
Or...you could just keep the water hose handy, Dave! LOL! Glad it turned out okay and nothing was lost, because of a fire! Stay safe!!!  Rick
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 6:47am
I agree... tougher in the wintertime, on account that the bucket is frequently frozen.  I have dry-chem extinguishers all over, too.  Big problems that occur with welding and torchcutting, is that 1) hot pieces scatter everywhere and 2) they hold LOTS of heat... so it frequently takes more than a quick blast from an extinguisher or a light splash of water to cool down the hot particle enough to prevent re-ignition of the fire.  With the equipment we work around, it's not unusual to find sources of stray lubricants, hydraulic fluids, and other debris... that's Class II mixed with CLASS I.
Having a cramped shop complicates the situation, as it puts too many things too close to the work zone, and of course, when things become an issue, too little space to maneuver.  During winter, most of us optimize our interior space to stay out of the weather... so these things happen.
Dilligence in cleaning prior to, observation during, and double-checking afterward, is the best modus-operandi.  One of the things I REALLY REALLY REALLY don't like doing, is finishing up a welding/cutting session and then walking away... I feel incredibly uncomfortable unless I've stuck around the workshop for at least an hour afterwards, just in case some little piece of something hot bounced off into a corner somewhere and started smoldering.  I guess that's a good discomfort.LOL
Glad it all turned out okay.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 6:50am
I know that feeling!!! One day in welding school, I was welding over head and started to feel my shoulder getting hot. About the time I raised my helmet up three guys from across the shop including my instructor tackled me. My whole right arm and shoulder was a fire ball. Little scary.
Can't fix stupid
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 7:00am
Up here we have this neat things that really work well. A red canister filled with chemicals. We call them fire extinguishers. Sorry I couldn't resist
PS glad you and your equipment are safe. Those can get outta control real quick
Edited by Redwood - 03 Apr 2013 at 7:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 7:19am
Here at work, we always have a fire extinguisher attached to the welding machine as well as the torch cart. Ya never know what'll happen or what could be going on around you when your welding or cutting till you lift the lid of that helmet! Its good to have an extinguisher or two right there to grab. Glad to hear yer' okay buddy and so is the machine. Hydraulic oil burns pretty quick when mixed with leaves and twigs for kindling. Don't ask me how I know dat....  Pinch
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 7:21am
Neighbor was cutting a piece of steel with a stihl gas powered cut off saw a couple of weeks ago near a corn stalk stack and it started the stack on fire they put out the flames then put the stack in the soupy steer lot and let them make crap out of it.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 7:23am
Last weekend I couldn't drive out the seat pivot bolt from it's rubber bushing so I decided to put the heat to it.  Little bits of burning rubber were flying off of it inside my shop.  I decided that inside my shop was not the best place to do this so I took it outside and continued.  It smoked for about 30 minutes after heating it more.  Good news is that it came out with one good hit of the ball peen without the rubber holding it.Thumbs Up
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 7:36am
I keep two gal of water sitting in the shop and have four big fire ex placed around the shop just for this. I Try to keep the shop clean too. Dave the Bobcat is a fire bug becouse they hold stuff down in there that like to burn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 7:43am
One winter, I was welding in insulated coveralls, on a V plow I was building.  Leaned against a hot spot, long enough to lite the coveralls up, at the knee!  I was stuffing snowballs into the leg, trying to get them off, wish I  had a video of it, could of made a ton on youtube.  All's I got is a little scar, where the metal part of the knee brace I was wearin, branded my knee, about the size of a quarter!
Jim seIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim seIl Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 8:18am
a grinder will start a fire quick and a long distance from work and David been there done that on a skid loader scary isn't it
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 8:29am
Dave, Good advice, as usual. I also need to make some metal spark screens to contain/deflect sparks from a grinder. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 3:26pm
Okay, since we're on the subject of setting clothing on fire...
It happens frequently when we're wearing welding shields, on account that we have limited peripheral vision, the clothes are heavy and hot to START with, and of course, we're sending fire everywhere...
So my two funny stories:
I'm TIG welding an aluminum gearcase (marine outdrive)... nothing unusual about that... but my left (rod) hand is getting warmer than usual... it's relatively cool in the shop (mebbie 40F or so), so it didn't bother me... aluminum rods conduct heat pretty fast...
Well, turns out that my welding gauntlet was on fire. I typically wear a lighter TIG glove in my right (torch) hand, and heaver glove in my my left, just for that reason. I keep the opposite gloves nearby, in the event that I hafta weld back-handed, but I rarely do so.
Turns out, that a buddy was over visiting a day or two before, and he grabbed my heavy (stick-hand) gloves to move a hydraulic reservoir. He wiped the oil off with a paper towel... of course, it wasn't enough to remove all the combustable residue, but he didn't realize that THOSE gloves had a specific purpose.
It took me a while to realize what that 'funny' smell was...
So my daughter's was in school... first or second grade IIRC... Teacher asks every child what happened at home this weekend that was fun...
She answers...
"Daddy set his shoes on fire..."
As you can imagine in today's highly-ignorant jump-to-conclusions 'we know better than you' attitude, they figure that warranted a call to the parents. Fortunately, my wife teaches at the school, so they asked HER... and she said...
"Of course- that happens all the time when he's welding."
Oh.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 6:10pm
Me smell mohican burning.  Me last mohican, MUST BE ME!
RickUP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickUP Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 6:21pm
Anytime you weld n grind on a gas powered machine, it's a good idea to have your wife,kids,or friend stand by as fire watch. They might be able to see things going bad before it gets too big. Darn gaseline is so fast. I'll be welding on one this wkend. I will try to be prepared.
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 7:05pm
and be sure to wear gloves and REMOVE YOUR WEDDING RING. I have a  permanent wedding band now.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 7:19pm
Just testerday I was doing some braseing, heard a strange whoosing sound. Turned my head and my dang shoulder was on fire. Shucked the coat in a BIG hurry, did the barnyard stomp. Used it again today. Guess I'll get the cold shoulder now! Leon
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 8:20pm
Why would you waste money on a fire extinguisher? LOL
My son dumped one of my dry chem's on a JD that he was doing a little cutting on and he had to go right past the water hose to get to it. It cost more to have it recharged then what the JD was worth. almost!! LOL  BTW no damage from the fire.
The universal answer to all questions is yes, how much do you want to spend?
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 8:22pm
glad it turned out OK Dave!!!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
James Coons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2013 at 8:44pm
Glad you weren't hurt and got it put out before things got out of hand. Machinery fires are not cool!
Edited by James Coons - 03 Apr 2013 at 8:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2013 at 6:15am
My tractors get pretty dusty out in the shop. I have to work where they are stored. I have covers to put on them, but because of the welding and grinding, I am afraid of getting the covers on fire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2013 at 2:26pm
I use a welding curtain when I am working in close proximity to stuff i don't want the sparks on.  I made them out of some 1" square stock and old canvas cotton trailer tarps.  I think most military surplus stores carry a similar heavy tarp.  throw a couple casters on so you can move them around easy. I don't have pics of mine but here's a link to some commercially available ones.
http://www.northerntool.com/shop/tools/NTESearch?storeId=6970&Ntt=welding%2Bcurtain
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2013 at 12:20am
A couple years ago I decided to mount a rear view mirror on my JCB skid steer loader. needed to weld a little bracket to the frame to mount the mirror to so first I watered down everything with the garden hose then covered the seat with a welding tarp.  Welded on the piece, took maybe 1 minute.  Everything seemed ok, took off the tarp and started bolting on the mirror, smelled plastic burning.  Looked down between the cab and seat platform and saw flames.  Poured more water on it and thought, "There, no problem."  Finished the mirror and started the machine up, the foot and hand throttle wouldn't work!  Got hot enough to melt the plastic housing and had to replace the whole throttle cable,$210.  Most expensive mirror I've ever had!
Allis Express participant
Sturgis CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sturgis CA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2013 at 9:27pm
A friend that I worked with at a welding/machine shop was working on a piece of farm equipment out in the field, it was dinner time and threw his jacket in the truck and left with someone else. Came back after lunch and his seat had caught fire from the coat that must have been smoldering but he did not know it. Lucky that the windows were up and it smothered itself out.
 David glad you and machine came out OK
It's not a hammer,It' a precision alignment tool!!
