What is it?
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Topic: What is it?
    Posted: 24 Mar 2013 at 3:49pm
 And what dose it go on for what use?  It came with some of the stuff I bought in the last two weeks.
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 4:00pm
It's a thingamabob extension.
HD16,917H,185,7050,8030FWA,8050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 4:23pm
 For a correct guess, I will show you.
sho-man1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote sho-man1 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 4:32pm
Ground drive pto off of a hay rake?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 4:34pm
With the ball hitch for Allis pull type equipment I wonder if there was a tractor that came up a little short on their PTO shaft. LOL Anybody know if Jeep PTO was standard from the shaft to the drawbar?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 4:36pm
Maybe to put on the back of a sickle mower to run a crimper?
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 4:36pm
At any rate, I don't have one and could use that guard on my CA I think Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 4:38pm
Our Allis crimper didn't have the ball hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 5:54pm
 you are correct except it is not a Jeep.  something old, red or gray.
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 5:56pm
ford
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 6:11pm
ferguson pto extension
arrowcreekfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arrowcreekfarms Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 6:29pm
I saw that at the auction saturday sitting in that old Roto-Baler
1972 200 diesel, 1966 190 Gas, 1962 D-15 Gas w/ #15 loader, SC 3-16" Plow, SC 8ft disc, SC 2 Row Cultivators, 500 Series 4 row Planter
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 7:33pm
Farmall F20 or F30 maybe?
Edited by Don(MO) - 24 Mar 2013 at 7:33pm
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 7:44pm
PTO extension for the Farmall F-20 tractors so they could operate AC equipment like the Allcrops, hayrakes,etc. The PTO's were tucked way under the differential. How many more do you need?Smile
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 8:21pm
Charlie, are you referring to the guard that looks like the pto guard on a B?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 8:51pm
YEP!!!!!!!
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2013 at 2:24am
the ball looks like the one for an allcrop hook-up.
been there done that, not doing it again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2013 at 3:28am
you got it, now the rest of the story, to come
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2013 at 5:08am
You know, when I saw it I recall when we hooked up a few combines to F-20 Farmalls.  They had the pto connection with the belt pulley under the transmission.  This extension allowed the F-20 to pull the combine without problem and made it an A.S.A.E standard hitch.
You know too, we loved to put the F-20 on the combine.  Why, cause it went so slow.  Had absolutely no problems.  With the WC there was always some "speed demon" who wanted to run the combine in THIRD GEAR!  In very light grain you could get away with it but not in heavier grain.  The F-20 gears were slower and worked GREAT on the 60 All Crop.
A real memory jolt and a piece of history.
Thanks for sharing.
Good Luck!
Bill Long
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2013 at 6:35am
I didn't see the AC ball until I went back and looked closer -- interesting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2013 at 4:03pm
We used to have a guy do custom silo filling for us. He had and allis blower with the power unit on it and I remember that it had the same ball hitch.
