Athens Bog Harrow
Mike(NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(NC) Quote  Post ReplyReply Direct Link To This Post Topic: Athens Bog Harrow
    Posted: 17 Jan 2010 at 12:09pm
_popupControl();   I'm trying to locate a spring for an Athens bog harrow. I think my Dad bought it in the 60's. The only tag I can find on it reads:
Athens Plow Co. Athens Tenn
G8 3714
  I have found the athens site but all they have there is offset or tandem harrows. Ours has 4 disk on each side and you back up set the angle you want and then forward to engage.  I need the spring that goes on the arm you lift or pull up to trip or dis-engage it. Any help will be appreciated. Thanks Mike
Higgins11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Higgins11 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 7:12pm
Did you ever find the model number or info on your Athens Disk?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 11:54pm
Farmall single straight disks used the same system. if you are gonna just use it, about any heavy spring should work, if you are restoring it, good luck, they went with the scapers! but might try springs off a corn picker!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 7:52am
Post a picture. I have a lot of NOS springs without a part number attached to them. About what do you think the dimensions for it are?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Higgins11 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 3:11pm
Anybody know the model number of this Athens
