AC 1300 Field Cultivator Sweep Size
dnel45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Topic: AC 1300 Field Cultivator Sweep Size
    Posted: 15 Mar 2013 at 1:02pm
What was the standard sweep size on the 1300 field cultivators?  I have a 24' that I am going to be replacing the sweeps on.  Were they all the same sweep size, front to back?  Shoup has an 8" sweep for $7.00 / ea.  Is this a pretty standard price?   Thanks
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 1:03pm
Yes they were all the same size.
             IG
llreckow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote llreckow Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 1:15pm
When the 1300 fld cult was new the recommend sweep size was a four inch sweep,all the sweeps were the same size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 1:21pm
Thanks for the info.  Would an 8" be okay on it?  Heavy clay ground mostly but usually use field cultivator for light shallow tillage before planting.
auctioneer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote auctioneer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 1:28pm
we sell a lot 7 inch the main thing make sure they are 54 degress
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 1:45pm
Alright thanks for the info.  What do you guys sell them for per shovel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote auctioneer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 3:24pm
$ 7.90 for a seven inch
$ 7.60 for 6 inch
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 3:40pm
To kill weeds I think they need to overlap. To stir dirt narrower will work, but when I tilled, I had spring weeds like wild mustard that I expected the field cultivator to cut off. And grass in some places where disking only seemed to encourage the grass to grow better.
I bought some from Shoup (www.shoupparts.com) that were only sharp on 2" of the front edge, they didn't cut weeds with the wings until I ground on them for a day. Shoup generally has good prices on sweeps, though one year the local IH dealer beat them considerably.
Gerald J.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 6:13pm
If you have heavy vegitation, the 1300 will choke up pretty quick, the wider the sweep the more it will clog up. On that model I would go as small as possible with the sweeps and still get weed kill.  We had one and used it mainly for incorporating chemicals. It didn't like many weeds..
Leon B MO
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 7:48pm
I have bought a couple sets from Shoup for my 1300 over the years.  I also used the Case IH earth metal ones for their cultivator that are 7 1/4" wide with good results, just theirs is a different angle and the Shoup one's we felt worked better.  We did have to shallow the depth adjustment after switching to the Shoup ones.  Shoup sweeps are 8".
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 7:55pm
Had a customer buy a set of 7 inch sweeps many years ago against my advice. He did 5 acres and came back and bought another complete set, only this time 4 inches wide. Untilled soybean ground will plug quickly with 6 or 7 inch sweeps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote llreckow Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 1:12pm
The spacing on your cult should be 6" between shanks,if you go wider than 6" sweeps
you will be just overlapping the sweeps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 2:23pm
And if you don't overlap weeds will slip through.
Gerald J.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 8:41pm
I forgot to mention, the larger sweeps work best in my sand ground.  They are not the best in the clay loam farm I have, best thing there are narrow sweeps of 4 inches at the widest and a whole lot of them on an S tine, I think, I just don't have anything set up for that farm...yet.
This page was generated in 0.523 seconds.
