plow for sale
Chris WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris WI Quote  Post ReplyReply Direct Link To This Post Topic: plow for sale
    Posted: 15 Jan 2010 at 11:07am
I have a 4-14 allis plow for sale works good, I used it this past fall. everything sand blasted and painted but coulters and tail lift wheel. also has the gauge wheel.  it is the age of wd45-early D-17 I think that makes it a 60 series. make offer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 11:33am
Wish I could find a five bottom like that for my WD45 diesel and D17 Diesel.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 1:24pm
hey chris would you email me a few close-ups of the gauge wheel and bracket/clamp on that thing? i am going to try to fabricate one for mine if i can't find another one
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 3:02pm
Hey! I need a complete gauge wheel asembly like that too! Close to Ohio would be nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 4:19pm
Butch - you and me both.  Have two with them but would like one to go on that 3-16's 73 I bought last summer.
Chris - that slanted mainframe beam going out for the 4th bottom on your plow is the most tell-tale way to determine it's a Model 64 plow.  The smaller square tube cross brace is the next way.  The slanted shank coulters I believe could have appeared on early 70 series plows but were a feature of the 60 series. Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 4:31pm
Got so excited about the gauge wheel I forgot the model question.  The slant beam plow models are 60-non adjustable frame, 70-adjustable frame shear bolt, 80-adjustable frame spring trip. Cant tell for sure because where I need to see isnt visable but looks like non adjustable frame so it is a 64
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 4:34pm
When did they switch from the short beaming screw to the long one? I have a 63 with the short one like on a 53, but you guys say this is a 60 series too. Did it get switched in the middle of the series? And how do you tell this 64 from a 74?
http://www.rumelyallis.com
John D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John D Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 4:40pm
here is a picture (if I do this posting right) of my model 73 with wheel assembly on it - if this helps any. The wheel slides up and down inside a piece of box steel with a set bolt in the middle of it.
http://i131.photobucket.com/albums/p293/jd1783/Model73plow.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 4:42pm
Rfdeere - the longer beaming screw on the 63 is due to it being a 4 bottom vs. 3 bottom I beleive.
To tell the 64 vs the 74 just look at the photo above of the 84 sitting next to it (ignore the spring trip bottoms and it pretend it's a 74).  Some items to spot:
* 70 series has adjustable frame as Butch points out.  All the main beams are squared off.  If you look closely you can see some double bolts where the frame beams overlap and bolt together.  That's where you unbolt and adjust from 14 to 16 & back.
* 74 has larger square tube cross brace that I mentioned above
* 70 series has taller plow beams for more trash clearance
* later 70 series has coulter shafts at 90 degree angles like in the photos
* beaming screw mounts differently in back on 74
Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote John D Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 4:46pm
This time for sure!
Before:
After:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2010 at 4:48pm
Nope The picture isnt helping, you need to unbolt it and send it this way, LOL
phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phil Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2010 at 10:53am
looking for a set for my 190 xt. are they to small?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2010 at 12:44pm
Plow coulters were used for many different frames, just like some bottoms. There were fewer coulter models than plow frame variations. Most clamped on the plow beam in front of the bottom. And while the 2000 series plow is taller there is a bar just above the plow moldboard sticking forward to carry the standard coulters that could have been on a 60, 70, or 80 plow frame.
Gerald J.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 6:20pm
Where in Wisconsin are you and what were you looking to get out of the 4 bottom plow?
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 9:59am
My booklet shows that the 1960 model 74 has the smaller square tube  and no square tube on the pre 1960 models. They are the high clearance  models !
