Cummins Heart Transplant
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Topic: Cummins Heart Transplant
    Posted: 10 Nov 2012 at 1:13pm
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2012 at 1:16pm
Hope the patient thrives.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2012 at 1:25pm
looks interesting........
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2012 at 1:30pm
Gettin it to mate up to the adapter plate has been a bear!!! That input shaft has to line up perfectly, then get all the holes to go together....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2012 at 3:22pm
Looks aggrivating, ,,,,, but it will be worth it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 8:01am
Did you bore the adpator plate or the Cummins seal or is seal behind plate?    MACK
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 6:23pm
Tractor model Cummins engine will be installed and and size of engine.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 7:06pm
Back plate so far set at 1/2 inch from block to get it to be spaced right for the pilot bearing. The original seal is used,  going to cut out that section on the plate so it will clear. Using a sfi cummins steel flywheel turned down to fit 7000 ring gear. starter will have to be spaced away from plate to contact ring gear, because a cummins crank protrudes 1 1/2 inch out of block, allis is flush. This is a 5.9 going into a 7000 chassis for a puller. hate to change it but bought a complete motor for the same price to get 301 rods hardend. As far as I know a 5.9 has never been instaled in a 301 tractor except the 7010 and 20.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 7:08pm
Need a starter spacer if anyone has one, they were used on power units with twinn disc clutches.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 7:09pm
Curious what class?  Around here the only guys that can run a Cummins are the Case guys as it was a factory replacement for the 504.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 7:14pm
IPA outlaw class in central il. a 5.9 is a replacemet according to agco
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 9:29pm
I adapted a 5.9 cummings into a 190XT for pulling a few years ago for a guy. MACK
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 9:58pm
I had a plate made to put a 5.9 in a 180. Its is 1" thick and used a 6 speed dodge flywheel cut down to the 180's ring gear.
But this is as far as i got.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2012 at 11:23pm
There is a 8030 with a 5.9 in it near me.  Nice job, air to air and all.
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 12:10am
One of my options is putting a 5.9 cummins in my D 21 tractor. Looking at all options. Looking at building a 516, or a 426, or a 5.9. I know it is less C.I.  BUT TO GET 1000 TO 1200 HP might be cheaper than the other route.
Keep us posted.
Thanks Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 7:34am
I wonder if these guys would have a mounting plate that would be close or able to be slightly modified for your Allis-Chalmers - Cummins project?  I used them for a Ford truck  conversion and found their products good.  Here is their weblink: http://fordcummins.com/
AndyinWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyinWI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 7:49am
There is a dealer in northern Wisconsin that sells complete kits for putting a 5.9 in 7000 / 8000 series tractors. pretty reasonable, and comes with everything but the engine. I will see if i can find their name and get it posted here for you guys.
Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 8:31am
Ag repower in indiana makes 8.3 and 5.9 conversion but not for 200, xt, 190, or older 301 tractors.
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 8:46am
I'm pretty sure I have the starter spacer you're looking for Bob......I'll be in touch, gotta find it :-/
Slade
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 9:24am
Sweet that's all i need to get this set up.
heavy12d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heavy12d Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2012 at 2:24pm
Andy, did you find the name of the place in Wisconsin?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyinWI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2012 at 5:26pm
The place in Wisconsin is Link Implement in Ridgeland, WI. They also have kits for IH tractors. Their phone number is 715-949-1795. I believe the fella I talked to was Rodger, he was very knowledgeable and seemed to really know 7000 and 8000 series tractors.
Andy
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 2:07pm
There was some talk a while ago about repowering tractors. Joe was asking about putting a v8 into things. I know this isn't the same but thought it was interesting and worth bring this old posting back up.
