ACC-40 Hydraulic Spools
razorsharp15 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorsharp15 Quote  Post ReplyReply Direct Link To This Post Topic: ACC-40 Hydraulic Spools
    Posted: 22 Oct 2012 at 5:23pm
My ACC-40 will slowly drop the fork blades and tilt forward until everything is touching solid ground (usually talking 1-2 hours from about 3 feet up) and I've been told that it could be the spools or the seals. Since it both tilts forward and the forks settle, I'm thinking the valve body needs rebuilding. Seals are easy to get, spools, not so much. Anyone know if there's a supplier for spools or if another valve body would (hopefully) drop in or be retrofittable.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2012 at 8:35pm
Still could be and is likely the cylinders packing leaking. On the tilt with 2 cylinders if one leaks it will still pull the oil from one through the other and leak down.
Yea, I can fix that.....
This page was generated in 0.359 seconds.
