D17 diesel head
DanNESD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Topic: D17 diesel head
    Posted: 18 Oct 2012 at 10:49pm
I took the head off my 17 diesel and there are cracks running from the injector holes up to the face of the combustion chamber. Does this mean the head is junk or is it still useable? The cracks are inside the combustion chambers...on all 6 cylinders!!!
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2012 at 7:58am
Probably just a stress crack...... if you cleand alot of those 262 heads, 99% of them would look like a road map with all of the cracks in them.  Have it pressure tested and if it holds pressure and non of the cracks are going near a water jacket, run it.
The right engine machinst can do a pin and stich and when he is done you will not know the difference.......of course this can be done.....for a price $$$$$
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2012 at 9:44am
Ok thank you very much...I'm going to see what my machine shop says!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2012 at 7:37pm
if you pull a 230,262 buda head,you will have cracks thru the injector ports and the web between the cylinders,on about 99% of them.no real deal if you are not loosing iol or water.....
