WD45 front hub question
Sterff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sterff Quote  Post ReplyReply Direct Link To This Post Topic: WD45 front hub question
    Posted: 14 Oct 2012 at 4:33pm
I was wondering what the right way is to take apart the front hub on a WD45 WFE.  Im assuming the hub nut is threaded but, I don't have a large enough wrench/socket.  How is this done?  Thanks
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2012 at 5:12pm
Pipe wrench, strap wrench, large adjustable wrench, C-clamp, pipe clamp.Thumbs Up
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2012 at 6:52pm
Pipe wrench. Take cover off , then take off the nut with the cotter pin then bearings slide out
1946 "C"
1956 "WD45"
1965 "D17" Series IV
1979 185 factory ROPS
deutz allis 385 planter
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2012 at 8:51pm
buy a bigger wrenchLOL If the hub cap on the one pictured needs to be taken off, clamp the hex cap in a vice and put a couple wheel lugs in 2 holes and put a pry bar between the lugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sterff Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2012 at 4:22pm
Thanks guys.  The one pictured is not mine, mine are still on the tractor.  Ill have to see if I can borrow a chain/strap wrench.
