6060 Tachometer
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Topic: 6060 Tachometer
    Posted: 12 Oct 2012 at 11:39am
Havent used this tractor a whole lot since I bought it in the spring but i noticed the other day while chopping stalks that the tenths roll backwards (9-8-7-6 etc) but the the hours still advance. this is the first time I ever saw this happen on a tractor. also the needle bounces between 18-21 regardless of throttle position?
Life is tough,but it's tougher when you're stupid. - John Wayne
Steve Zidlicky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Zidlicky Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 12:32pm
don't know about the rolling backwards part but a poor connection at the alternator will cause eratic function of the tac.  you may have a more serious problem.  if someone else does not have an answer I can look up the problem in the service manuel tonight.  By the way, I have a new genunine allis 6060 service manuel if you are interested. NO BINDER INCLUDED.  60.00 plus the ride.  I gave more than that for mine in 1984.
Longmeadow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Longmeadow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 12:37pm
You might have an electrical connection problem regarding the tach, but I had a 6080 needle bounce, while the hour meter seemed to work properly... including the tenths position... about 5-6 years ago... I replaced the tach...problem solved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 1:22pm
Electrical would make sense because the alternator idiot light recently started to flicker
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 5:37pm
Agco has new tachs 238 , just priced one!
