Parking tractors for the winter
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Parking tractors for the winter
    Posted: 08 Oct 2012 at 11:59am
The snow flakes are getting closer!
I did some research on stabil gas stablizer, and found that they make a 'marine blend' stabil that is used for ethanol blends of gasoline. Car collectors are using this now, because we have ethanol in our unleaded gas.
Just thought I would pass this on, did not know they made this blend.
Galatians 5:22-24
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 12:42pm
I think Seafoam is also blended for the ethanol fuels. Been using it and like it better than Stabel.
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 1:17pm
Seafoam is the way to go!
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 3:20pm
There is also stuff called Star-Tron that was the first product on the market for ethanol-blended fuels. I have a buddy who owns a small engine shop who says it's top notch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 4:14pm
I use Seafoam. I'll have to take a look and see what the Star-Tron says. That is, if I can find it.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 5:24pm
You mean the standard Stabil is not good for ethanol blends. I did not know that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 6:00pm
Standard Stabil is just fine for ethanol fuel. All Sea Foam is is isopropyl alcohol and light machine oil. I've used Stabil for years in ethanol fuel. If you don't like alcohol in your fuel, why add Sea Foam?
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 6:04pm
i've only used sea foam to clean intake systems is it advertised for stabilizer?
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 10:15pm
Drain the tank, run until it dies....no problems!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 6:04am
Just goin by what these fellers said....
Eldon, how in the world do you have time to drain the gas tanks on all those tractors?
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 6:46am
Always used Stabil but SeaFoam cleans the fuel system. If you have one you can crank enough to pull the fuel into the carb with SeaFoam in it, let it sit a day and it will usually start and run. The longer it runs, it will clean itself out and keep you from a carb rebuild. Otherwise, Stabil is great for fuel storage. Mike
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 7:17am
I dosed my tanks with both types of Stabil and then filled the tanks up to the top to prevent any condensation.  Shut the gas off and drained the carbs.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 7:41am
I've always used good ole' dry gas in my tanks whether its the Tractors or the hotrods. Seems to always work fine. Tractors and cars fire right up during the winter months and I run them for about 15 minutes or so just to get things moving and the engines up to operating temps. Never had a problem all these years. Noticed a couple months ago the throttle shaft lever on the B was getting loose. Took the carb off, repaired the lever, and just for jollys thought I would pop the top of the carb off to see what it looks like inside. After all, its been almost 10 years since I restored the ole' girl. Inside that carb looked like the day I rebuilt it! I was impressed to say the least. I add a dash of dry gas everytime I fill one of my machines. So far, knock on wood, no fuel related problems at all! Heard a lot about the Seafoam, especially on this site, but never tried it. Sounds like everyone swears by that product....
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 8:36am
A bottle of Dry Gas is cheap insurance once in a while if you don't always buy your gas at the same place or fill up just after a fuel drop when the storage tank gets stirred up. Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 9:31am
Out here with the low humidity it doesn't  take much for what little I put in my gas tractors to evaporate.....and just for that reason, most of the tractors I use are now diesel.
ALLIS EXPRESS!
This year:
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 9:49am
I have over a dozen tractors in my back yard that will get Sea Foam treatment and the anti freeze get checked and added to if necessary. I also make sure the ones that have batterys have a fresh over night trickle charge. It has worked for me for many years
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 10:22am
For the diesels, make sure you aren't using Bio-diesel if you plan to let it sit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 10:34am
I still use a seafoam product in my diesels, helps keep any algae blooms and moisture under control.  Was suggested by the local MFA for my supply tank too if I don't use much this winter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 11:07am
Isn't dry gas mostly alcohol and since gas has 10 ethanol (alcohol) why do we need dry gas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 11:44am
I am not a huge seafoam fan.
Put some in the D-19D, and it ran worse than before.
Galatians 5:22-24
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 12:06pm
Big time ditto on that!
Wink
I am a Russian Bot
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 3:41pm
Isn't all diesel bio nowadays?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 9:18pm
not all is created equal. the lower % you use, the better off you'll be. B5 will be much better than B11, or especially B20.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 9:55pm
I'm sure it is minimal out here since the nearest soy is probably the midwest....also too dry for algae growth.
ALLIS EXPRESS!
This year:
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2012 at 7:53am
Well here is my superswtition, on something to go along withh the stabil.
I add outboard motor oil.  It has worked for years in my two cycle stuff, so my thoughts are that it will help with keeping things preserved in the gas fuel system.
