K2 in corn how fast
BiG210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiG210 Quote  Post ReplyReply Direct Link To This Post Topic: K2 in corn how fast
    Posted: 07 Oct 2012 at 6:59pm
How fast can you run a K2 in corn with 3 row head. 1st. or 2nd. gear in good standing corn
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2012 at 7:23pm
Never had one but my A2 & F2 run on lower side of 2nd in good corn. 3-30's on the A2 and 4-30's on the F2.This is 180+ bu corn running whole cobs.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2012 at 7:28pm
I would say 1st gear in good corn. The cleaning shoe is rather small for a 3 row in todays yields. Although our drought stricken corn at our farm you could shell it in road gear!!! Ryan
ranger42 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2012 at 7:42pm
We ran K2 with 2 row head for years in 150 to 200 bushel corn in second about as fast as we could go if it was dry corn.  It would really eat up 15% corn, but above 20% we slowed down considerably.
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 6:54am
second gear vith variable speed back in most cases with my old short back K2.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 6:58am
Used to drive in 2nd at a pretty good clip with the E and 2 row head in 150-180 bu corn but today I'm sure I'd be in 1st with 200 plus corn. A K2 is just a little bigger. Did they make a long shoe K2? That would be better.
Wink
I am a Russian Bot
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 12:59am
K2s cylinder can easy thresh 250+ bpa corn. Especially if aggressive rasp bars are installed. Problem become getting grain from cleaning shoe up to grain tank. Grain moisture dictates much. 24%&higher adds considerable weight to grain. You can add a speed up kit to clean grain elevator. So, 2nd gear is very possible, but grain volume & density will determine variable speed - low or high.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger42 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 6:14am
yes 7060 that was our weak link...when the corn was a little wet the clean grain elevator was overloaded....we did not have the speed up kit on it however.
