Off color - fuel leak
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Topic: Off color - fuel leak
    Posted: 07 Oct 2012 at 1:27pm
Had fuel leaking from the top of the engine on my Hindu Ford (Farm Trac 35). Found a hole in the fuel return line behind the #3 injector. The line was made of some type of plastic but I replaced it with a section of 1/4 inch fuel line. Will this line work or do I need to try to find a piece of the plastic line? Parts for these tractors are somewhat hard to find and expensive. Nice utility tractor but not nearly as well built or reliable as AC. Got it from my BIL a few months before he passed away. Only has 153 hours on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2012 at 1:41pm
On return line it should make no difference as long as the line is made for petroleum products . It only flows fuel back under low or no pressure .
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2012 at 3:07pm
JB weld
