AC B Sediment bowel #%$*
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: AC B Sediment bowel #%$*
    Posted: 06 Oct 2012 at 3:20pm
Just venting , no response required. I have a  B with a sediment bowel that I can't get to stop dripping even with the pet cock turned off. I have re-plumbed everything twice and even tightened the packing nut.   GERRRRAngry
Terry/EasternIa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry/EasternIa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 5:05pm
Are you using a cork gasket not rubber on the bowl ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 5:16pm
Well hopefully is is not leaking because of a crack in it. We were on a tractor ride and a fellow had a leaky one on a Farmall H. It ended up it the line was cracked. Terry is right..Make sure you are using a cork gasket on the bowl. I had a rubber gasket that came on the new sediement bowl unit but it leaked...got a cork gasket and not more leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 6:18pm
Those pot metal bases can get warped from over tightening the bail and will never quit leaking till you replace it or chuck it in a lathe and re-cut the seat. If it leaks when it's supposed to be shut off, it needs replacing anyway unless there is a chunk of crud in the shut-off.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 8:38pm
Leaking bowels are always nasty!!!  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2012 at 9:21pm
Thanks guys.
Ted
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2012 at 9:11pm
When your tightening the bail on the bowl give the bowl a twist just as it seats.
Dusty
MBwcIll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2012 at 9:23pm
My guess it is a bad metal base.  The last D 15 we worked on would not stop leaking after I cleaned out the junk in the bowl.  Two new gaskets would not stop it (tried both rubber and cork). I just happen to have a new assembly and put it on and re-using one of the just used gaskets it stopped leaking.  Then, I could  see the original metal base was out of round.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 5:13pm
Solved the problem. In my set up the sediment bowel screws in to a male/female nipple (typical for AC  B) and the nipple screws into the tank. The sediment bowel that I have has about 3/8 in extension above the threads which if  screwing directly into the tank would stick up into the tank to keep dirt out. This extension which is part of the cast sediment bowel was bottoming out into the nipple and not allowing the threads to seal. Solution was to cut off this extension. Now it screws in tight and does not leak. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 7:30pm
Way to go Ted. It is sure a good feeling when you fix it and it is fixed!
Pastor Mike
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2012 at 10:39pm
The glass on my gleaner E leaked, new cork, new rubber, didnt matter. Last week I took the bail off, turned it 180, tightened it a little by hand, no more leak. 3 years of leaking, tightening with a plier, swearing, head scratching, and fixed in 30 seconds by flipping the bail! go figure, Trev.
