18.4 34 tires
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: 18.4 34 tires
    Posted: 01 Oct 2012 at 8:14pm
Just was wondering if anyone had any good reveiws on cheaper tires like Delta or Sampson or any others. I lost a rear tire on my 190XT and am tring to figure out after labor and fluid work if its worth the savings to look at the cheaper tire. As it sits now I can get a firestone SAT ll for $1000 mounted and new tube with fluid, and labor. It appears that firestone is phasing out Field and Road in favor of the new SAT ll, anyone have any thoughts on them?
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 8:27pm
Firestane sat is a great tire, digs good in field, wears good on road. the sat2 is only slightly different than the sat, still 23 deg. i think. around here you can still get the sat so you may still be able to match if that what you had. 1000 is not bad just paid 1200 for the same
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 9:26pm
i think TITAN bought the FIELD & ROAD patern from Firestone. i have bought the cheeper tires and had good luck with them. Akaret is a good cheep tire.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2012 at 6:07am
u may wanna look around for a pair of used tires/rims. i had found a local set for our d-19 they where firestone radials with 80%tread and good condition rims for $800/pair. that beats $2500 for new rims,tires, tubes ,labor etc.etc. not sure where your located at, but norm on here has some. good luck
