Busy B, Also Help ID'ing Implements
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Topic: Busy B, Also Help ID'ing Implements
    Posted: 30 Sep 2012 at 12:12am
The B worked hard the last two weekends and we enjoyed every minute of it!  Hope you enjoy the pictures.
Please feel free to give advice as I am new to most of this.  Also, if anyone know what type of valve I could use to direct the flow of the hydraulic pump so that I can use either the loader of 3-point without disconnecting, please post a link, I would very much appreciate it.
Started Saturday off with a little brush hogging.  I ended up doing a four acre field that has not been cut in five years and widened and cut a few new trails to walk on out back. Anyone recognize what type and model brush hog that is, I need to replace the wheel bearings.
Next, I plowed up about an acre total between the three spots. I even managed to get stuck once!  Maybe I was plowing a little too deep, lol.  Anyway, does anyone know what model AC plow this is, what size it is and what year it may have been made?  I'd like to purchase the manual for it.
The next day I disced the field and went over it with a spring tooth harrow (drag).  The B did all of this on one take of gas, I was impressed! Also, does anyone know the make and model of the disk and drag?  They both have the letters PA with numbers stamped on them.
I ended the day by taking the dog for a walk, not that she is ever far away from the B while it is running!
Today I spread 800 + lbs of lime and tomorrow we will seed 180 lbs of winter rye, 120 lbs of spring oats, 80 lbs of winter peas, 24 lbs of red clover, and 10 pounds of radishes.
Edited by Dean (West MI) - 30 Sep 2012 at 12:16am
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 5:36am
Very nice setup, and still earning her keep.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 6:15am
Dean, I installed a diverter valve on my CA to allow me to use either the front snowblower lift or the rear 3 pt. The valve will hold either lift in up position when the other is selected and the  up and down is then operated by the original lift control.
There are differences between the B and the CA in that the CA pump has a higher volume output. It must be painfully slow lifting that loader with the original B pump?
If you'd like more particulars on my diverter valve PM me and I'll send pics.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 7:28am
I have never seen a B using a bushhog before, bet there isn't any carbon on the plugs of that old girl after all that work! Thanks for sharing the pictures looks like a nice little field.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 7:39am
How the heck did you get that furrow so deep?! Them old tractors still do a lot of work.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 8:42am
I like seeing the old tractors still working.
You might watch out for that hole next year. lol
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 8:48am
Awesome! Love seeing the old gals earning their keep! Thumbs Up
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 9:31am
You need a two way valve. There was one that came on some of the b/c's not sure how common they are. I have one. I believe they were used for the two way plows
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 3:46pm
Thanks! I think I saw pictures in another thread. Now that I know what the valve is called, I can start looking for one online.
The loader is very slow. Actually, I use it more to counterbalance heavy loads on the 3 point. I'm not sure if I want to install a pump on the crank like Steve has to give the tractor live hydro or look for some B engine and wishbone weights.
Edited by Dean (West MI) - 03 Oct 2012 at 3:49pm
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2012 at 4:29pm
Dean,  It is GREAT to see my favorite in action.  Really hard work that was done the old fashioned way by bush hogging, plowing, disking,  harrowing, and spreading lime.
Like the arrangement for the loader.
Thanks for taking such good care of my favorite.
Good Luck!
Bill Long
This page was generated in 0.110 seconds.
