301 engine dipstick tube
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Topic: 301 engine dipstick tube
    Posted: 25 Sep 2012 at 1:13pm
On one of our 185 tractors, the tube that holds the dipstick and protrudes through the block into the oilpan has become loose.  Anyone know of a way to tighten this up without using JB weld as someone at the dealer suggested.  Thanks, David
AlVee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlVee Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 1:51pm
dimple it from the inside and black rtv silicone
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 5:04pm
Clean both surfaces and use red loctite.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 5:47pm
take it out and knurl it with a pair of vice grips and then drive it back in,
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 7:30pm
Take a wedge-type concrete anchor just small enough to fit in, and run a screw into it. You can do the same by sticking in a smaller aluminum tube and doing the same... or run a lag screw in it. I've warmed 'em up red and stretched dipstick tubes a smidgen with a phillips screwdriver... and then apply any favorite concoction of techno-spit to it. I like two-part epoxy, but any techno-goo will doo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 9:34pm
Thanks for the input guys.  As soon as I get my gasket for the oil filter housing, this will get due attention.  Of the three 301 engines we have, this is the only that has loosened up.
