How to remove manifold bolts on WD45?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Topic: How to remove manifold bolts on WD45?
    Posted: 23 Sep 2012 at 8:06pm
Should I attempt to remove these and risk breaking the manifold bolts off in the head or just let the machine shop do it when the head is rebuilt?  Two came out but the others are not playing nice.Cry  Tips or tricks on doing it if I so dare?
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 8:12pm
Looks like all you need is a torch and a pipe wrenchErmm If it were mine, I would be taking them out because I would be doing the "machine" work on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 8:15pm
Charlie do I heat just the bolt or the head also as in direct the heat at the base of the bolt?
1968 one-seventy
1956 F40 Ferguson
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 8:50pm
heat the head around the bolts and get a pipe wrench or large vise grip with good teeth clamped on the bolt as close to the head as possible and see if you can inch it out, if it breaks off shouldn't be the end of the world to drill and tap I think you can see the back of the hole thru the water jacket
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 9:36pm
Thanks Bill.  Worst case is I break them off and the machine shop will get them out for me.  I'll stop if I break the first one as I'm sure there is an increased cost to having them drilled out thats well above them getting them out for me.  May give it a try tomorrow night if I have any propane for the torch.
1968 one-seventy
1956 F40 Ferguson
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 6:16am
What about the heat and parafin (candle) wax thing. Apparently it wicks down the threads at an amazing rate! I`ve yet to try it but I sure will the next time I face the challenge.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 7:10am
The original studs are good quality steel, and the head is good quality iron... when gripped close to the head, they've always come out nice for me... I've never had one break off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 7:54pm
Thanks you guys it did just as you said.  Heat plus a pipe wrench and they all came out.  Last one was the worst and I was getting that feeling I always get right before something snaps but it came out also.  One less thing to worry about.  Thumbs Up
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 7:56pm
Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 10:33pm
Way to go Stan!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 7:27am
See, just the threat of parafin wax helps! Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2012 at 8:31am
LOLLOLLOLLOLLOL
1968 one-seventy
1956 F40 Ferguson
