WD45 diesel- fuel in the oil
thatch14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thatch14 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 diesel- fuel in the oil
    Posted: 23 Sep 2012 at 10:28am
My brother has a WD45 diesel that he just noticed has fuel in the oil. He had 2 of the injectors worked on when he first got it. Would that have something to do with the other injectors? We farm about 66 acres and I was getting all pumped up about plowing wheat stubbles with it this year. I'd appreciate any advice. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 10:47am
There is a bad seal in the injector pump that allows fuel to get to the oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thatch14 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 10:54am
Is that an easy fix?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 11:37am
usually a seal on the transfer pump shaft, and a groove worn in the shaft from an old hard seal. You can repair the PSB transfer pump fairly easily. Just finding parts if yours needs the shaft. We've had to send the shafts out to be built back up before. Not very expensive, but a little bit of a wait.
Richard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 6:19pm
I had that happen several years ago and the fix was replace both seals on the shaft - one seal cost 90 cents and the other cost 92 cents.  This was back in the late 70's.  Both seals looked alike but each had a specific place, one for oil and the other for fuel.  I remember taking a picture with a camera and you'll want to at least take a mental picture before you remove the shaft, in other words know exactly how it's going to be going back together.  Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 6:20pm
One other note - I remember talking to a fellow that said he replaced both seals on the shaft on an annual basis just so he wouldn't have any trouble.
