AC 7 Rake
jkennard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkennard Quote  Post ReplyReply Direct Link To This Post Topic: AC 7 Rake
    Posted: 22 Sep 2012 at 7:08pm
I have a AC7 Rake that is a side delivery rake. It is missing the pto shaft, and I am trying to outfit a new one for it. I bought a Weasler Eng complete shaft but the end supposed to hook up to the rake is a 1 3/8" round and I need a 1 1/4" woodruff key end to hook to the rake. I cannot find a way to change the yoke out due to the fact that the only yoke I could find that is a correct size woodruff key yoke is too wide to fit the bearing part (not sure that this is what its called). I really like the rake and really want to be able to use it especially since it matches my 1936 AC WC unstyled. Any help would be greatly appreciated. I had a lot of people tell me that I was crazy when I tried to get my 1950s Oliver mower operable and that it couldnt be done. but I did it, so I know that its just a matter of knowing exactly what I need and where to look for it. If anyone knows of a used shaft or a way I could adapt one I would greatly appreciate it!!!!!! THanks!!!
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2012 at 6:06pm
First off.  Are you sure that it is a #7 rake?  They are commonly mistaken for a pto side delivery rake.  Does it have a shifter with a high low and revearse option or does it have two shafts sticking out the front of the gearbox?
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkennard Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 10:03am
I saw someone on here say it was a #7. it is an ac side deliver rake with a 3 speed trans. high low and tedding. it has two wheels. i got a new pto shaft and am trying to outfit it with a keyway from weasler. cost me as much as the rake itself(250). hopefully i can get operational. Even if the new shaft works i am still looking for an original shaft for historical purposes and tractor shows etc. Thanks for the reply. i would also like to try to find another just like it if anyone has one for sale in illinois or a surrounding state.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 10:06am
if it has a 3 speed gear box on it then it is NOT a #7 hay rake. It is just a standard rake. Very common, there are lots of those units around for parts just ask in the classifieds section and I bet you will find one. Also pictures will help alot too.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2012 at 1:17pm
I think this is what you need, but the rake end connection is for a 1 inch keyed shaft on the gear box. Also if you purchased a one piece shaft, you may find that a problem also.
This came from an operational rake that sacrificed its future so that another may live.Clap
Orangereborn
Dale Schafer
964 192nd Ave
New Richmond, WI 54017
715-247-3079
715-781-2055
Orangereborn@hotmail.com
This page was generated in 0.199 seconds.
