D12 with throw out noise
krieg1952 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote krieg1952 Quote  Post ReplyReply Direct Link To This Post Topic: D12 with throw out noise
    Posted: 22 Sep 2012 at 4:11pm
I have a 1959 D12 that makes a lot of noise at the throw out bearing. Is the throw out bearing servicable or does it have to be replaced? Thanks in advance.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2012 at 4:13pm
Did you try to grease it?
Edited by JoeO(CMO) - 23 Sep 2012 at 7:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote krieg1952 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2012 at 4:21pm
How do I get to it to grease it?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2012 at 4:55pm
Krieg
I checked in an Allis 'Operators Instructions Manual' for the early D-10 and D-12
and was suprised that there was no mention about lubricating the clutch release bearing.
Gary
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2012 at 8:24pm
Most T/O nearings I have seen are sealed bearings (it is adjacent to the clutch/pressure plate and grease is not compatable with them); believe the D12 has a sealed T/O bearing.
Is the noise constant...or is it noticeable when you depress the clutch? A constant noise indictates a worn T/O bearing; noticeable only when the clutch is depressed indicates a dry or worn pilot bushing/bearing.
One needs to split the tractor to service the T/O bearing and/or pilot bushinf/bearing. Sometimes, one can re-grease a T/O bearing similar to regreasing wheel bearings; however, its probably best to replace the T/O bearing seeing as how much is involved to access it, and the cost of a new one is reasonable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 8:30am
Worth noting on the newer units where a perceived throw-out bearing noise had us scratching our heads. Sounded like the throw-out bearing but all had been replaced with new. Turned out we needed to make a new bushing at the rear of the hollow quill shaft as the worn bushing noise travelled forward through the torque tube.
Drove us nuts on a late 1960 D12, equipped with live hydraulics and live PTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2012 at 10:01am
Aetna offered a greasible throwout bearing for the D series. Use common sense and grease sparingly. HTH Tracy Martin
