Fuel line fittings? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Topic: Fuel line fittings?Posted: 13 Sep 2012 at 1:46pm |
What and where can you purchase the original type male tube and female carb and bowl fuel line fittings? Thanks Tracy Martin
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 13 Sep 2012 at 2:36pm |
Tracy - are they not standard brass flare fittings? We used off the shelf brass plumbing flare fittings and bent flared brake line to replace the fuel line on my D17 Series IV back in 2006 and it worked great. Looks original to me. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Tracy Martin TN
Posted: 13 Sep 2012 at 3:09pm |
Mike, They are inverted flare fittings, but I can't remember what they are called. I have the outside female type now. Looking for a male internal type. Thanks Tracy
Butch(OH)
Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Posted: 13 Sep 2012 at 4:06pm |
Tracy the threads and flare are the same as used on U.S. brake lines,, at least he older ones I am used to. A double flare tool as used on the steel brake lines wil make for nice leakproof flares on the copper tube but a std tool will due. The modern made fittings such as the 90 pipe to tube fitting for the carburetor may not look like the originals depending on how old the equip is. NAPA used to have al manner ofsuch and if you still have a REAL hardware store around they will have both types of flare fittings and nuts.
Tracy Martin TN
Posted: 13 Sep 2012 at 7:53pm |
Butch, Thanks for the info. Tracy Martin
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 13 Sep 2012 at 9:20pm |
I got them at NAPA also. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
GlenninPA
Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Posted: 13 Sep 2012 at 9:22pm |
Tracy, the only trouble I have had is getting flares that have the 1/8 MIP end to tie into the sediment bowl or carb. You need to find someone who has a full line of flare/ 1/8 MIP fittings. Glenn
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
countryguy828
Joined: 11 Sep 2009 Location: Arcanum, Ohio Points: 129 |
Posted: 13 Sep 2012 at 9:55pm |
I'd try McMaster Carr. I got aluminum 1/8 inch line and fittings from them for my CA and B. It's been several years ago though. Dave |
