WC radiator
Ed-In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed-In Quote  Post ReplyReply Direct Link To This Post Topic: WC radiator
    Posted: 12 Sep 2012 at 4:34pm
I guess old age is setting in,,,,, can someone tell me the direction  the coolant flows from the radiator to the motor......top to water pump to motor or just the opposite? thanks, right now i'm drawing a blank.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 5:38pm
From the bottom of the rad through the engine, back to the top of the tank.  I coul;d be wrong, but I think the water pump pulls the collant into the block, then forces it out through the thermostat back to the top tank.
AaronSEIA
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 8:09pm
 The hottest water comes from the cylinder head, thru the pump into the rad, drops to the rads bottom as it cools , and rises thru the block as it warms, and so it goes......
