Allis 200 front wheel and hub
CBL95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBL95 Quote  Post ReplyReply Direct Link To This Post Topic: Allis 200 front wheel and hub
    Posted: 10 Sep 2012 at 6:52am
Does anybody out there have a good used front hub for a 200 they'd be willing to part with?? Or know if our existing one can be drilled and tapped? 4 or the six lug bolt holes are stripped out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:11am
If you don't care what it looks like, use a drive in stud from the backside like a car and a nut on the outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBL95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:18am
Do you mean to get the same sized press-in type stud like on my pick up and press them into hub? If so that sounnds like a good idea cause I'm not really concerned how correct it looks right now just more concerned that I can use it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:35am
Yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CBL95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:36am
I don't know why I hadn't thought of that earlier, thanks dr
LRWSPWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LRWSPWI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 10:13am
I used a thread insert in mine!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 10:17am
I've drilled and tapped 1/2" to 9/16" easily with my cordless drill. I had the 9/16" lug bolts just laying around....IMHO, AC should have used larger lugbolts in their front wheels, I have seen lots of failures.
ALLIS EXPRESS!
This year:
Dan (SE MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan (SE MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 10:29am
Use a longer lug bolt and put a nut on the back side of the hub.  Our 7000 has been like that for a few years without any issues.  It was a temporary repair, but you know how that goes sometimes.  I'm embarrassed to say that we even have a new hub sitting on the shelf.  Maybe this winter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 12:05pm
I always put 2 studs in even in good treads hub, its a booger getting the dam wheel on and the bolts started
