Shift cover gasket wd45
Manure Queen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Manure Queen Quote  Post ReplyReply Direct Link To This Post Topic: Shift cover gasket wd45
    Posted: 09 Sep 2012 at 9:43pm
Just pulled the transmission/gearshift cover on the WD45 to inspect.  Good shape.  Now, need to replace gasket.  Where might I find one?  Also, getting ready to make a gasket for PTO housing.  Thickness?  I'm guessing pretty thin material.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:22am
AGCO still makes both gaskets. THe PTO gasket is paper thin. If you make a gasket that's too think you will make too much play in the gears adn they won't mesh right
Post Options Post Options   Thanks (0) Thanks(0)   Quote Manure Queen Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:48am
Thanks, Dave.  Anyone have the part number for both gaskets as well as the oil seals at the PTO shaft/housing?  I'm waiting for my parts catalog to come and my local Agco is all about the parts number on older tractors.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 10:39am
you can look it up here. http://www.agcopartsbooks.com/PartsBooksN/login.aspx?ReturnUrl=%2fEpsilonWeb%2fbook.aspx%3fbook%3dagco%2f79001544&book=agco%2f79001544. If your useing the old parts book the numbers will be wrong anyway.
Edited by Dakota Dave - 10 Sep 2012 at 10:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Manure Queen Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 11:07am
Dave,
Thanks a million.  This is a GIANT help.  I can find everything I need.
